Device driver initialization sequence
Fri Nov 9 10:32:52 UTC 2018
Hello Yaroslav,
the initialization sequence is documented here:
https://docs.rtems.org/branches/master/c-user/initialization.html#initializing-rtems
I would not use the I/O Manager. Working with major/minor numbers is
quite painful. I would initialize custom devices in the initialization
task. If you need the POSIX file descriptor API for your devices, then I
would use IMFS_make_generic_node() to register them.
On 09/11/2018 11:25, Ярослав Лещинский wrote:
> Hello,
> I read the documentation about I/O Manager, found different source
> codes where mentioning not only rtems_io_* functionality but also
> drvmgr*, rtems_libio* and another mechanisms which are referred to
> device driver topic and I have a feeling that I'm missing something.
> Could you please correct me if I'm wrong in the following steps of
> initialization of device driver:
> 1. define *CONFIGURE_MAXIMUM_DRIVERS* macro
> 1. Create *rtems_driver_address_table *and register it via
> *register_io_register_driver*
> 2. Write all necessary functions for *rtems_io_initialize,
> rtems_io_open, etc*
> 3. Associate name with major:minor pair using *rtems_register_name*
> As I understood there are can be a lot of different device drivers
> tables and I should somehow get the right major:minor driver from the
> right table. How I can do this?
> Kind regards,
> *Yaroslav Leshchinsky*
> users mailing list
> users at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
