Task sync problems related with binary semaphore and cache memories
Tue Nov 27 13:45:17 UTC 2018
On 27/11/2018 13:23, Arturo Perez Garcia wrote:
> Hi, I have been facing thread synchronization problems.
> I was trying to synchronize two threads using a binary semaphore to
> protect critical parts of the code. Today I realized that the
> semaphore was been acquired sequentially by both threads before It was
> released by any of them. This behavior has been fixed when I have
> disabled the cache memories, either the data cache or instruction
> cache. Could you give me some hint about this??
> I'm using our own BSP for the zcu102, which was generated by modifying
> the xilinx-zynq bsp for the RTEMS release 4.11.3. This behavior can be
> related to a wrong implementation of the BSP??
Please run the smplock01 and smpatomic01 on your board. I guess the
cache snooping is not enabled.
SMP is experimental in RTEMS 4.11. I would use the RTEMS master.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
