wrong behavior binary semaphore
Fri Nov 30 14:32:30 UTC 2018
On 30/11/2018 15:23, Arturo Perez Garcia wrote:
> Hello,
> I did more tests using the same source files. But modifying the
> priority of the threads and the scheduling algorithm used in the
> creation of the semaphore. What I was expecting (and what I need) is
> this:
> task 1 start
> ld adq by kernel. kern_1
> ld rel by kernel. kern_1
> exe adq by kernel: kern_1
> sleeping kernel : kern_1
> task 2 start
> exe rel by kernel: kern_1
> ld adq by kernel. kern_2
> ld rel by kernel. kern_2
> exe adq by kernel: kern_2
> sleeping kernel : kern_2
> exe rel by kernel: kern_2
> Where the semaphore is sequentially obtained and released by the same
> thread each time it has been acquired.
You have to consider that each rtems_semaphore_release() may make a
higher priority thread ready (task 1) which wants to obtain the
semaphore, so the output of the release is delayed until task 1 waits on
something, e.g. the rtems_task_wake_after().
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
