wrong behavior binary semaphore
Arturo Perez Garcia arturo.perez at upm.es
Fri Nov 30 14:23:27 UTC 2018
Hello,
I did more tests using the same source files. But modifying the priority
of the threads and the scheduling algorithm used in the creation of the
semaphore. What I was expecting (and what I need) is this:
task 1 start
ld adq by kernel. kern_1
ld rel by kernel. kern_1
exe adq by kernel: kern_1
sleeping kernel : kern_1
task 2 start
exe rel by kernel: kern_1
ld adq by kernel. kern_2
ld rel by kernel. kern_2
exe adq by kernel: kern_2
sleeping kernel : kern_2
exe rel by kernel: kern_2
Where the semaphore is sequentially obtained and released by the same
thread each time it has been acquired.
I was supposing that once a semaphore is acquired by one task, it could
not be obtained by another task until it was released by the first task
that acquired it; independently of the tasks priorities. Now, looking at
the test results I can affirm that there are no errors in RTEMS and my
supposition was wrong.
Thanks so much for the support Sebastian.
Regards.
El 2018-11-30 12:53, Sebastian Huber escribió:
> On 30/11/2018 11:55, Arturo Perez Garcia wrote:
>> Hello, thanks for the feedback. I checked the confdefs file and the
>> macro CONFIGURE_MAXIMUM_SEMAPHORES is set to 0 by default. I don't
>> know why I didn't get those errors.
> I used the RTEMS master to run the test. In RTEMS 4.11 the default
> configuration contains some semaphores may be used by the system.
>> Once RTEMS is correctly configured. Did you obtain the same results as
>> me?
> task 1 start
> task 2 start
> Looks all right to me considering that task 1 has a higher priority
> than task 2 and the semaphore uses FIFO ordering.
Arturo Perez Garcia - arturo.perez at upm.es
Researcher
Center of Industrial Electronics
Universidad Politecnica de Madrid
