rtems_message_queue_receive / rtems_event_receive issues
Catalin Demergian
demergian at gmail.com
Thu Oct 11 13:37:25 UTC 2018
Hi,
Yes, there is a call to rtems_task_wake_after in the code; but in that case
state should have been STATES_DELAYING, right ?
At another run, I got
state = 0x0 = STATES_READY
Wait.flags = 0x104 = THREAD_WAIT_CLASS_EVENT | THREAD_WAIT_STATE_READY_AGAIN
Why would the state be ready in _Event_Seize ? could that value be corrupt ?
I tried with the stack checker as well, but I didn't see any out of band
values.
Catalin
On Thu, Oct 11, 2018 at 11:17 AM Sebastian Huber <
> On 11/10/2018 09:52, Catalin Demergian wrote:
> > Hi,
> > I don't use malloc myself in the code I added, but I see it is used a
> > lot in the networking code.
> > I printed state and Wait.flags for SCrx task
> > * when all is ok *
> > in _Event_Seize, after _Thread_Dispatch_enable
> > state = 0x100 = STATES_WAITING_FOR_EVENT
> > Wait.flags = 0x102 = THREAD_WAIT_CLASS_EVENT | THREAD_WAIT_STATE_BLOCKED
> > in _Event_Surrender at the beginning
> > state = 0x100
> > Wait.flags = 0x102
> > * when SCrx is not scheduled any more *
> > Wait.flags = 0x02 = THREAD_WAIT_STATE_BLOCKED
> > state = 0x0
> > Wait.flags = 0x02
> > do these look like valid values ? I mean in _Event_Seize the state
> > should have been blocked, right ?
> > can these values be caused by a corruption ?
> A thread wait flags value of 0x02 indicates that this thread used
> rtems_task_wake_after() recently (at least in RTEMS 5, but very likely
> also in RTEMS 4.11.2).
> > -> Did you check the task stacks with the stack checker?
> > I'm afraid I don't know how to use it in RTEMS. any link to
> > information on how to detect/analyze a data coruption in RTEMS can be
> > useful.
> It is a configuration option
> #define CONFIGURE_STACK_CHECKER_ENABLED
> In the RTEMS shell you can obtain the task stack information with the
> "stackuse" command.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/users/attachments/20181011/01193103/attachment.html>
