rtems_message_queue_receive / rtems_event_receive issues
Thu Oct 25 11:18:32 UTC 2018
On 25/10/2018 13:03, Catalin Demergian wrote:
> This is really strange. If you use cpsid/cpsie around the append_cnt ++
> and --, then append_cnt should never be > 1. If this really the case,
> then this looks like a processor bug.
> -> No, after I saw that it didn't fix the problem I commented the
> dis/en, so
> the value 2 was obtained without the dis/en in the code.
Maybe you could replace the arm_interrupt_disable/enable with the
cpsid/cpsie (you need support for nesting).
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
