RTEMS tools invalid version file
Heinz P. Junkes
junkes at fhi-berlin.mpg.de
Mon Oct 29 12:03:42 UTC 2018
Try to run waf in rtems tools:
[h1 at earth rtems-tools (master)]$ ./waf configure
--prefix=/home/h1/RTEMS/rtems/5.0 build install
Setting top to : /home/h1/RTEMS_DEV/rtems-tools
Setting out to :
/home/h1/RTEMS_DEV/rtems-tools/build
invalid version file: error: Invalid revision config value:
/home/h1/RTEMS_DEV/rtems-tools/config/rtems-version.ini: 0.not_released:
descriptor 'isdigit' requires a 'str' object but received a 'unicode'
(complete log in /home/h1/RTEMS_DEV/rtems-tools/build/config.log)
[h1 at earth rtems-tools (master)]$ more
# project configured on Mon Oct 29 12:58:24 2018 by
# waf 1.9.9 (abi 99, python 2070fc1 on linux2)
# using ./waf configure --prefix=/home/h1/RTEMS/rtems/5.0 build install
Setting top to
Setting out to
from /home/h1/RTEMS_DEV/rtems-tools: Could not load the Waf tool
'doxygen' from
['/home/h1/RTEMS_DEV/rtems-tools/.waf-1.9.9-75529a659e4f06cb4254801e52405e0a',
home/h1/RTEMS_DEV/rtems-tools',
'/usr/local/lib/python2.7/dist-packages/setuptools-18.0.1-py2.7.egg',
'/usr/local/lib/python2.7/dist-packages/pyepics-3.2.4-py2.7
.egg', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-x86_64-linux-gnu',
'/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
'/usr/lib/python2.7/lib-dynlo
ad', '/home/h1/.local/lib/python2.7/site-packages',
'/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packag
es/gtk-2.0', '/usr/lib/python2.7/dist-packages/wx-3.0-gtk3']
No module named doxygen
from /home/h1/RTEMS_DEV/rtems-tools: invalid version file: error:
eleased: descriptor 'isdigit' requires a 'str' object but received a
'unicode'
No idea about doxygen, but this is installed on the system I am using:
[h1 at earth rtems-tools (master)]$ which doxygen
/usr/bin/doxygen[h1 at earth rtems-tools (master)]$ doxygen
error: Doxyfile not found and no input file specified!
Doxygen version 1.8.13
Copyright Dimitri van Heesch 1997-2015
You can use doxygen in a number of ways:
Heinz
Das FHI verarbeitet, speichert und loescht Daten im Rahmen seiner
Geschaeftstaetigkeit gemaess der Datenschutz-Grundverordnung (DSGVO)
[General Data Protection Regulation (GDPR)] der Europaeischen Union.
