RTEMS in AMP mode
Alan Cudmore
alan.cudmore at gmail.com
Wed Oct 17 16:03:25 UTC 2018
Is the POSIX API preferred for RTEMS applications moving forward?
Thanks,
Alan
On Wed, Oct 17, 2018 at 5:20 AM Sebastian Huber <
> On 15/10/2018 14:23, Thawra Kadeed wrote:
> > Thanks a lot Sebastian for referring me to the git master.
> > Actually, I cloned the current git master and I was looking for the
> > RTEMS kernel (source code) and I have found it in this path:
> > "rtems-master/cpukit/rtems"
> > I think this is the RTEMS library which constitutes the RTEMS kernel
> > in general irrespective to other features and modules attached to it.
> > Is that right?
> This directory contains the Classic API implementation which I would not
> use in new applications. The core operating system parts are in
> cpukit/score.
> > On the other hand, RTEMS supports dynamic memory allocation (DMA) and
> > priority inheritance. However and as I understood from you, if we
> > choose priority-based scheduling (which is another scheduling policy)
> > and static memory allocation by the App, then the executable file will
> > automatically have only these features without by example the DMA, so
> > I think it is all the App dependent, right?
> RTEMS uses currently dynamic memory (the so called workspace) internally
> for some things. This was also the case 20 years ago. Maybe we can get
> rid of using dynamic memory in some time. By default, it is only used by
> the operating system during system initialization.
> Only the services used by the application and the operating system are
> included in the executable. For example, if you don't use the FAT file
> system, then the stuff for the FAT file system is not in your executable
> even though the FAT file system support is in the librtemscpu.a which
> you used to link your executable.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20181017/c24ca9d6/attachment-0002.html>
