Thu Oct 25 15:07:50 UTC 2018
On Thu, Oct 25, 2018 at 7:38 AM 18Y5C31 ZENON HANS TANEKA <
zenon.hans.taneka at dhs.sg> wrote:
> Hi! I am a GCI student working on a task. I am meeting the problem of
> 'make' returning the error
> *** No rule to make target 'all'.  Stop.
> make[2]: Leaving directory
> '/home/zehata/development/rtems/kernel/pc686/i386-rtems4.11/c/pc686'
> Makefile:359: recipe for target 'all-recursive' failed
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory
> '/home/zehata/development/rtems/kernel/pc686/i386-rtems4.11/c'
> Makefile:483: recipe for target 'all-recursive' failed
> make: *** [all-recursive] Error 1
Did you put the RTEMS bin directory at the front of your PATH before you
ran bootstrap or sb-bootstrap? Make sure your PATH picks up the RTEMS
version of autoconf.
How did you configure?
Did you make a "build directory" separate from the source tree?
Just let us know what steps you followed and we should spot the issue.
> How may I resolve this?
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20181025/7421b25d/attachment-0002.html>
