Console API
Ярослав Лещинский midniwalker at gmail.com
Mon Oct 29 11:01:37 UTC 2018
Hello Sebastian,
Thank you for the link. As I said previously I would like to contribute --
add BSP for stm32l476. Is it possible?
If answer is yes I would like to clarify some moments about workflow:
1. Do you have any code requirements, e.g. code style?
2. What is a process when someone added a new code to the master? Should I
create a new branch from master? What about push request? Etc.
BRs, Yaroslav.
On Fri, 26 Oct 2018 at 20:15, Sebastian Huber <
> Hello,
> for new BSPs, please use the Git master. The console driver documentation
> on the master is up to date:
> https://docs.rtems.org/branches/master/bsp-howto/console.html
Kind regards,
*Yaroslav Leshchinsky*
URL: <http://lists.rtems.org/pipermail/users/attachments/20181029/eae6b04c/attachment-0002.html>
