rtems_message_queue_receive / rtems_event_receive issues
Catalin Demergian
demergian at gmail.com
Wed Sep 26 06:43:07 UTC 2018
HI,
When you say "changing the makefiles" who's makefiles are these?
-> for example lib/rtems-4.11.2/c/src/lib/libbsp/arm/stm32f7/Makefile.am
in order to include my USB .c and .h files
Did you merge your code into the RTEMS
source tree?
-> yes, there was no support for USB in the code base I had
Do you have a JTAG debugger that can set breakpoints and step at the
instruction
level?
-> yes
regards,
Catalin
On Wed, Sep 26, 2018 at 1:10 AM Chris Johns <chrisj at rtems.org> wrote:
> On 25/09/2018 21:37, Catalin Demergian wrote:
> > what does it mean exactly to run with the RTEMS master ?
> This is our short hand for saying use the development version of RTEMS,
> specifically the next release called RTEMS 5. It requires cloning a couple
> of
> git repos and using them rather than the releases. The work flow should be
> the
> same. This code is stable at the moment and should work.
> > The problem is like this: I initially had a USB stack for my STM32F7
> that was
> > working on a bareboard (no OS)
> > Starting from that, I integrated that USB code in RTEMS 4.11.2. This was
> a long
> > duration task, until I got it working
> > a spent a lot if time changing the makefiles first to add my new files
> to the
> > project, then analysing the USB bus with a sniffer
> > and various other stuff to see it working.
> I have done this myself on a NIOS a few years ago. It is a lot of work.
> > To try with another RTEMS version would mean redo the USB integration; I
> can't
> > consider this as a viable option because it
> > would take a long time until I would be in the same place, and there are
> no
> > guarantees it will not fail in the same way.
> I think I may be missing something here. Did you merge your code into the
> RTEMS
> source tree?
> > I think the only good option would be to debug in my code base and
> understand
> > what's going on.
> This is understandable.
> instruction
> level?
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20180926/a00077d8/attachment-0002.html>
