Application build in Eclipse gives error
Amarnath MB amarnath.mb at mistralsolutions.com
Mon Apr 1 08:42:22 UTC 2019
Yes, it is.
This had happened because of a git pull error, my entire toolset directory
got deleted.
But I had a back up of the working toolset and the above errors are from
that copy.
*Thank you & Regards,*
*Amarnath MB*
Module Lead | Software
*[image: cid:image003.png at 01D34802.FAE459C0]*
No 60, Adarsh Regent, 100Ft Ring Road, Domlur Extension, Bengaluru –
560071. INDIA
*P:* +91-80-3091 2600 *D:* +91-80-3073 1431
*E:* amarnath.mb at mistralsolutions.com    *W:* *www.mistralsolutions.com*
<http://www.mistralsolutions.com>
On Thu, Mar 28, 2019 at 6:51 PM Joel Sherrill <joel at rtems.org> wrote:
> This is going to sound like a stupid question but has part of the toolset
> been deleted? Search for those libraries at the install point. It is
> unusual to see that set.
> On Thu, Mar 28, 2019, 3:50 AM Amarnath MB <
> amarnath.mb at mistralsolutions.com> wrote:
>> Hi All,
>> I have been building the application for a custom ARM926EJ-S SoC using
>> RTEMS CDT in eclipse, unfortunately from yesterday onwards I'm getting this
>> below error
>> Building target: RTEMS_APP.exe
>> Invoking: RTEMS Linker
>> C:/opt/RTEMS/5.00/compiler/5/bin/arm-rtems5-gcc
>> -BC:/opt/RTEMS/5.00/bsps/5.00/SoCV1/arm-rtems5/SoCV1/lib/ -specs bsp_specs
>> -qrtems -ffunction-sections -fdata-sections -mcpu=arm926ej-s -mfpu=vfp
>> -mfloat-abi=hard -Wl,--gc-sections -o "RTEMS_APP.exe"  ./init.o
>> c:/opt/rtems/5.00/compiler/5/bin/../lib/gcc/arm-rtems5/7.4.0/../../../../arm-rtems5/bin/ld.exe:
>> cannot find crti.o: No such file or directory
>> cannot find crtbegin.o: No such file or directory
>> cannot find -lgcc
>> cannot find -latomic
>> cannot find -lc
>> cannot find -lgcc
>> collect2.exe: error: ld returned 1 exit status
>> make: *** [makefile:51: RTEMS_APP.exe] Error 1
>> My development platform is MingW64 on Windows 10.
>> The strange part is that when I build my BSP from MingW shell then this
>> error is not reported and everything gets built successfully. Once I
>> install my bsp and use it in eclipse to build application it gives the
>> above error.
>> After some googling, I came to know that this is some issue related to
>> the Linker standard path.
>> Can anyone help me solve this error?
>> *Amarnath MB*
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20190401/427d1029/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20190401/427d1029/attachment-0001.png>
