RTEMS scheduler bug ?
Catalin Demergian
demergian at gmail.com
Mon Apr 1 12:28:55 UTC 2019
Yes, I made a test, _ISR_Get_level() can be used on my CPU.
About --enable-rtems-debug .. it doesn't seem to enable the RTEMS_DEBUG
flag in the code, I tried --enable-rtems-debug=yes as well ..
is there maybe a combination of options to enable RTEMS_DEBUG in the code ?
I'm afraid I will run for nothing without it, it seems the
Assert is defined to nothing if this is not set right.
regards,
Catalin
On Fri, Mar 29, 2019 at 3:36 PM Sebastian Huber <
> On 29/03/2019 14:31, Catalin Demergian wrote:
> > Sure, I will build and try.
> > Is _ISR_Get_level() something CPU-specific ? I mean we use it to
> > figure out if interrupts are enabled or not, right ?
> > forgot to say, I use a STM32H7. Does _ISR_Get_level work on it ?
> I would run test
> testsuites/sptests/sp37
> to figure out if it works.
> > Also, I thought the scheduler code runs with interrupts enabled, I
> > mean doesn't it use the tick interrupt itself ?
> > How does that work on RTEMS ?
> Some critical sections of the scheduler are protected by disabled
> interrupts.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/users/attachments/20190401/b0ad213f/attachment.html>
