RTEMS scheduler bug ?
Catalin Demergian demergian at gmail.com
Mon Apr 1 12:51:33 UTC 2019
yes, removing the build dir did the trick :)
I'll start a test with the assert in and let you know.
Catalin
On Mon, Apr 1, 2019 at 3:31 PM Sebastian Huber <
> On 01/04/2019 14:28, Catalin Demergian wrote:
> > Yes, I made a test, _ISR_Get_level() can be used on my CPU.
> Ok, good.
> > About --enable-rtems-debug .. it doesn't seem to enable the
> > RTEMS_DEBUG flag in the code, I tried --enable-rtems-debug=yes as well ..
> > is there maybe a combination of options to enable RTEMS_DEBUG in the
> > code ? I'm afraid I will run for nothing without it, it seems the
> > Assert is defined to nothing if this is not set right.
> You have to remove the build tree and configure again:
> configure --target=arm-rtems5 --enable-maintainer-mode
> --enable-rtems-debug ...
URL: <http://lists.rtems.org/pipermail/users/attachments/20190401/a631ac92/attachment-0001.html>
