RTEMS scheduler bug ?
Mon Apr 1 12:31:21 UTC 2019
On 01/04/2019 14:28, Catalin Demergian wrote:
> Yes, I made a test, _ISR_Get_level() can be used on my CPU.
Ok, good.
> About --enable-rtems-debug .. it doesn't seem to enable the
> RTEMS_DEBUG flag in the code, I tried --enable-rtems-debug=yes as well ..
> is there maybe a combination of options to enable RTEMS_DEBUG in the
> code ? I'm afraid I will run for nothing without it, it seems the
> Assert is defined to nothing if this is not set right.
You have to remove the build tree and configure again:
configure --target=arm-rtems5 --enable-maintainer-mode
--enable-rtems-debug ...
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
