[altcycv_devkit] Access to FPGA Fabric via HPS2FPGA Bridge
Christian Spindeldreier
spindeldreier at ims.uni-hannover.de
Tue Apr 2 09:08:49 UTC 2019
Hi,
thank you for the advice on the mmu config which we missed. One has to
enable the device memory region as follows:
arm_cp15_set_translation_table_entries(device_addr_start,
device_addr_end, ARMV7_MMU_DEVICE);
Afterwards one can access the device memory as described before.
We use a nightly build of the RTEMS master, but we do not see the RTEMS
Fault Manager, as some kind of ISR prints out the content of the
register file and performs a warm reset when any error occurs. I assume
that u-boot (2018.11) and the MPU Watchdogs are in charge of this
behavior but we havn't found the point to disable it yet.
Best regards,
Christian
On 29.03.19 13:28, Sebastian Huber wrote:
> Hello,
> On 29/03/2019 12:57, Christian Spindeldreier wrote:
>> Hi,
>> currently we experimenting with the RTEMS-5 on a Cylcone V SoC-FPGA
>> using the altcycv_devkit BSP. Now we are trying to access a simple
>> hardware module connected to the HPS2FPGA Bridge via an AXI
>> interconnect. Our approach of simply write data to the corresponding
>> address or using the 'alt_write_word()' function which basically does
>> the same, results in a system crash, so i guess we are missing
>> something.
> for this platform please use the RTEMS master and not RTEMS 4.11 or
> something like that. You should first get more information about the
> system crash. I would install a custom fatal error handler which
> prints out the termination reason, see also
> rtems_exception_frame_print(). With it you can get the exception
> reason and the program counter.
> I guess, the MMU is not set up to allow an access to this region:
>> *((volatile uint32_t *) 0xC0000000) = (uint32_t) 1UL;
>> alt_write_word(0xC0000000, 0x01);
Dipl.-Ing. Christian Spindeldreier
Leibniz University Hannover (LUH)
Institute of Microelectronic Systems
Architectures and Systems Group
Appelstr. 4, 30167 Hannover, Germany
voice : +49-511-762-5039
fax : +49-511-762-19601
mail : spindeldreier at ims.uni-hannover.de
web : http://www.ims.uni-hannover.de/spindeldreier
