RTEMS scheduler bug ?
Thu Apr 4 12:28:02 UTC 2019
Hello,
On 04/04/2019 14:09, Catalin Demergian wrote:
> Hi Andrei,
> thank you for the elaborated answer !
> I checked my STM32 Cube settings, I have 3 enabled interrupts and they
> all have the preemption priority/sub priority set to zero !
> it seems I ran into the same issue you had in 2015 :)
> I will take your advice - change the priorities, regenerate the code
> and see what happens.
I mentioned this possible problem some months ago:
https://lists.rtems.org/pipermail/users/2018-September/032600.html
Andrei's answer is definitely a bit more elaborate.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
