rtems_binary_semaphore_post from IRQ handler
Ярослав Лещинский
midniwalker at gmail.com
Wed Apr 17 13:25:23 UTC 2019
Hello,
I wrote spidev driver for stm32l4 mcu.
spi_trasfer function looks like:
static int spi_transfer(
spi_bus *base,
const spi_ioc_transfer *msgs,
uint32_t msg_count)
struct stm32l4_spi_bus *bus = (struct stm32l4_spi_bus *)base;
SPI_TypeDef *spix = (SPI_TypeDef *)bus->driver.spix;
enum spi_major_num num = get_spi_major_number(spix);
bus->msg = &msgs[0];
spi_bus_table[num] = bus;
spi_bus_table[num]->msg_count = msg_count;
spi_bus_table[num]->messages_left = msg_count;
int msg_error = spi_setup_trasfer(
spi_bus_table[num],
spi_bus_table[num]->msg,
spi_bus_table[num]->messages_left);
rtems_binary_semaphore_wait(&bus->sem);
return (msg_error == 0)? 0 : -EINVAL;
Transmission proceeded via SPI IRQ + DMA IRQ. In DMA IRQ handler after dma
successfully transmitted all data I'm using rtems_binary_semaphore_post for
corresponding semaphore.
bool bus_is_broken = (bus == NULL) ||
(msg_count < bus->messages_left) ||
(msg_count == 0);
int ret = 0;
if(bus_is_broken == true)
return -EINVAL;
if(msgs->cs_change == true)
spi_css_deselect(&bus->driver);
if(bus->messages_left > 0)
const size_t msg_idx = msg_count - bus->messages_left;
ret = spi_do_transfer(bus, msgs, msg_idx);
bus->messages_left--;
if(ret != 0)
rtems_binary_semaphore_post(&bus->sem);
return ret;
else
return ret;
Currently I see that semaphore was successfully posted but control was not
returned to spi_transfer.
As I know there are can be some issues with a context switching.
Does rtems_binary_semaphore_post know about where control should be
returned?
Thanks.
Kind regards,
*Yaroslav Leshchinsky*
URL: <http://lists.rtems.org/pipermail/users/attachments/20190417/6bc77eda/attachment.html>
