RTEMS GCC BIG ENDIAN SUPPORT
Fri Aug 2 06:48:48 UTC 2019
Hello Tom,
I don't use RTEMS 4.11. In the RTEMS 5 documentation you see the
available multilibs for ARM:
https://docs.rtems.org/branches/master/cpu-supplement/arm.html#multilibs
Some background information about multilibs:
https://docs.rtems.org/branches/master/user/hardware/architectures.html
For a big-endian Cortex-R you need the following compiler flags in RTEMS 5:
https://git.rtems.org/rtems/tree/bsps/arm/tms570/config/tms570ls3137.inc
Did you build the tools using the RSB:
https://docs.rtems.org/branches/master/user/start/index.html
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
