RTEMS GCC BIG ENDIAN SUPPORT
Fri Aug 2 08:14:08 UTC 2019
On 02/08/2019 10:08, Aby Tom wrote:
> Dear Sebastian Huber,
> Thank you for your quick response. I have checked links that you send me.
> I have configured everything as per the documentation. And it is
> working fine. By this I mean that, my sample application worked
> perfectly with RTEMS 4.11.
> I build the tools using RSB. But in a mailing list (
> https://lists.rtems.org/pipermail/users/2003-February/006996.html ) I saw
> arm-rtems-ld supports big-endian target, it's arm-rtems-gcc which doesn't
> It's ld failing to link, because it finds that rtems has been compiled
> for big-endian, while the gcc/newlib-infrastructure only supports
> little-endian targets.
> Of course, this is a very old explanation to the thread and I believe
> there is a proper solution available now. I just could not find it.
> So I would like to know how can I implement big-endian multilib into
> rtems arm gcc.
> I guess this could be a solution to my problem. Correct me if I am wrong.
Please build the tools with RSB. I checked RTEMS 4.11 and the right
multilibs are present.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
