Eclipse and RTEMS on Zynq
Wed Aug 28 22:44:22 UTC 2019
On 28/8/19 6:23 pm, Andy James wrote:
> I’m using the Eclipse plugin for RTEMS (on Eclipse and Xilinx SDK) , yet when I
> attempt to run the executable (via JTAG) on my Zynq Dev board the program
> Doesn’t appear to execute properly, with no terminal output. If I build the
> sample “hello” within RTEMS itself, that appears to work fine. What am I missing?
Are you also running the hello.exe the same way via JTAG?
Have you used the required machine options when compiling _and_ linking your
executable?
