CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER macro issue
Michel Macena
mmacena.eng at gmail.com
Fri Aug 30 16:33:49 UTC 2019
Thanks for the answer, but the ticker sample program
has this macro in his system.h header. I can compile a program
with this macro but when I load it, the board just ignores it an then
reset. If I change the
macro for the opposite one ("does not need the clock driver") the program
just works, except that I can't
use any time related routine. Also without the clock drive driver enabled I
can't communicate with the board (send and receive data).
I understand that the Macro enables the clock drive but how this happens ?
It changes a register value in the chip ?
Em sex, 30 de ago de 2019 às 03:21, Sebastian Huber <
sebastian.huber at embedded-brains.de> escreveu:
> On 30/08/2019 19:09, Michel Macena wrote:
> > I still have the issue with the macro #define
> > CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER. I tried
> > a different version of RTEMS but It didn't work. Can someone explain me
> > how this macro works? So I can
> > try to figure out some patch or fix for my hardware.
> This configuration option enables the clock driver.
> I would run first the RTEMS test suite on your target. For example start
> with the ticker sample program.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/users/attachments/20190830/32b14d1d/attachment-0002.html>
