sparc and trap 4 (floating point disabled)
Joel Sherrill
joel at rtems.org
Tue Dec 3 19:54:35 UTC 2019
On Tue, Dec 3, 2019 at 8:48 AM Schweikhardt, Jens (TSPCE3-TL4) <
Jens.Schweikhardt at tesat.de> wrote:
> Hello, world\n
> I have a question about the use of trap 4 by RTEMS on Sparc32 (leon3).
> Since our app needs FP, we set the PSR[EF] bit during the boot process
> before RTEMS is invoked.
> Since we don’t expect the fp_disabled trap (4) to occur, we install a
> fatal handler for it with
> rtems_interrupt_catch(&fatalTrapHandler, 4, &old);
> However, the fatalTrapHandler is invoked a short time after application
> start (we use the Init() task
> and start a handful of additional tasks, all of which have attribute
> RTEMS_FLOATING_POINT)
> and the PSR[EF] bit is indeed cleared. None of our tasks
> clears that bit, so we suspect RTEMS does it for some reason.
Is the Init task floating point? What thread is executing when the trap
occurs?
The IDLE thread is likely integer only if you are looking at it is running.
> Question: is an RTEMS/sparc application allowed to install a handler for
> trap 4? I could not find an
> answer in the docs for SPARC Specific Information.
I think that's OK.
> Thanks for any insight!
> Regards, Jens
> Tesat-Spacecom GmbH & Co. KG
> Sitz: Backnang; Registergericht: Amtsgericht Stuttgart HRA 270977
> Persoenlich haftender Gesellschafter: Tesat-Spacecom Geschaeftsfuehrungs
> GmbH;
> Sitz: Backnang; Registergericht: Amtsgericht Stuttgart HRB 271658;
> Geschaeftsfuehrung: Dr. Marc Steckling, Kerstin Basche, Ralf Zimmermann
> [image: banner]
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20191203/2c144629/attachment.html>
