sparc and trap 4 (floating point disabled)
Schweikhardt, Jens (TSPCE3-TL4)
Jens.Schweikhardt at tesat.de
Tue Dec 3 14:48:30 UTC 2019
Hello, world\n
I have a question about the use of trap 4 by RTEMS on Sparc32 (leon3).
Since our app needs FP, we set the PSR[EF] bit during the boot process before RTEMS is invoked.
Since we don't expect the fp_disabled trap (4) to occur, we install a fatal handler for it with
rtems_interrupt_catch(&fatalTrapHandler, 4, &old);
However, the fatalTrapHandler is invoked a short time after application start (we use the Init() task
and start a handful of additional tasks, all of which have attribute RTEMS_FLOATING_POINT)
and the PSR[EF] bit is indeed cleared. None of our tasks
clears that bit, so we suspect RTEMS does it for some reason.
Question: is an RTEMS/sparc application allowed to install a handler for trap 4? I could not find an
answer in the docs for SPARC Specific Information.
Thanks for any insight!
Regards, Jens
________________________________
Tesat-Spacecom GmbH & Co. KG
Sitz: Backnang; Registergericht: Amtsgericht Stuttgart HRA 270977
Persoenlich haftender Gesellschafter: Tesat-Spacecom Geschaeftsfuehrungs GmbH;
Sitz: Backnang; Registergericht: Amtsgericht Stuttgart HRB 271658;
Geschaeftsfuehrung: Dr. Marc Steckling, Kerstin Basche, Ralf Zimmermann
[banner]
URL: <http://lists.rtems.org/pipermail/users/attachments/20191203/35d0bbdd/attachment.html>
