RTEMS ethernet stack and drvmgr
Wed Dec 4 14:01:48 UTC 2019
On 04/12/2019 14:59, Joel Sherrill wrote:
> On Wed, Dec 4, 2019, 8:54 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 04/12/2019 14:49, Jan.Sommer at dlr.de <mailto:Jan.Sommer at dlr.de> wrote:
>      > Hello everyone,
>      > Since I just read the question from Fernando, I was wondering if
>     the (recommended) Ethernet stack of rtems-libbsd does work with the
>     greth driver of the drvmgr as well?
>      > The greth driver, as most of the other Ethernet drivers of other
>     BSPs,  calls the ether_ifattach function at some point.
>      > In the current sources of FreeBSD the prototype of this function
>     seems to be different.
>      > Do I understand it correctly that all drivers doing that are only
>     compatible to the network stack included with "-enable-networking"?
>     All drivers written for the old network stack need to be converted
>     manually to the new network stack (libbsd). We did this for at least
>     four drivers before and it is mostly a boring semi-mechanical task.
> The Gaisler drivers in the RTEMS source tree is for the legacy stack.
All network drivers in the RTEMS source tree are for the legacy stack.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
