AW: RTEMS ethernet stack and drvmgr
Jan.Sommer at dlr.de
Wed Dec 4 14:12:18 UTC 2019
Thanks,
I think I get it now.
So for example the
https://git.rtems.org/rtems/tree/bsps/arm/atsam/net/if_atsam.c is the legacy one.
And https://git.rtems.org/rtems-libbsd/tree/rtemsbsd/sys/dev/atsam/if_atsam.c is the newer version ported to libbsd.
Best regards,
Jan
-----Ursprüngliche Nachricht-----
Von: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
Gesendet: Mittwoch, 4. Dezember 2019 15:02
An: joel at rtems.org
Cc: Sommer, Jan; rtems-users at rtems.org
Betreff: Re: RTEMS ethernet stack and drvmgr
On 04/12/2019 14:59, Joel Sherrill wrote:
> On Wed, Dec 4, 2019, 8:54 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> On 04/12/2019 14:49, Jan.Sommer at dlr.de <mailto:Jan.Sommer at dlr.de> wrote:
> > Hello everyone,
> > Since I just read the question from Fernando, I was wondering if
> the (recommended) Ethernet stack of rtems-libbsd does work with the
> greth driver of the drvmgr as well?
> > The greth driver, as most of the other Ethernet drivers of other
> BSPs, calls the ether_ifattach function at some point.
> > In the current sources of FreeBSD the prototype of this function
> seems to be different.
> > Do I understand it correctly that all drivers doing that are only
> compatible to the network stack included with "-enable-networking"?
> All drivers written for the old network stack need to be converted
> manually to the new network stack (libbsd). We did this for at least
> four drivers before and it is mostly a boring semi-mechanical task.
> The Gaisler drivers in the RTEMS source tree is for the legacy stack.
All network drivers in the RTEMS source tree are for the legacy stack.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
