RTEMS Release Snapshot: 5.0.0-m1912 (05 Dec 2019)
Tue Dec 17 07:12:52 UTC 2019
On 17/12/2019 07:46, Sebastian Huber wrote:
> On 17/12/2019 07:31, Sebastian Huber wrote:
>> On 16/12/2019 23:34, Michael Davidsaver wrote:
>>> On 12/4/19 8:58 PM, chrisj at rtems.org wrote:
>>>> RTEMS Release Build - 5.0.0-m1912
>>>> RTEMS 5 Release snapshot m1912 is avaliable for testing.
>>>> It can be found at:
>>>>   https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m1912
>>>> Please test and report any issues to the user at rtems.org or
>>>> devel at rtems.org
>>>> mailing lists or please raise a ticket.
>>>> If you are part of the RTEMS testing program please build on your
>>>> preferred
>>>> host posting build and BSP test results to build at rtems.org.
>>>> This is a development release and may have errors and be unstable.
>>>> Thanks
>>>> Chris
>>> Building on a Debian 10 host I get a link error in the rtems-tools
>>> package involving LLVM.
>>> It looks like the build is using the host LLVM (deb llvm-dev
>>> 1:7.0-47).  Is this supposed to
>>> be the case?
>> Thanks for testing the snapshot. I tried to build the rtems-tools on a
>> Debian 10 of the GCC compile farm (gcc68), but it seems the LLVM
>> development packages are not installed:
>>>  From the resulting rsb-report-rtems-tools-5.0.0-m1912-1.txt:
>>>> Checking for 'gcc' (C compiler)          : /usr/bin/gcc
>>>> Checking for 'g++' (C++ compiler)        : /usr/bin/g++
>>>> Checking for library LLVM                : not found
>>>> Checking for header llvm/DebugInfo/Symbolize/Symbolize.h : yes
>>>> Checking for library ws2_32                              : not found
>> It seems you have the header files, but no library was found. Maybe we
>> should only build the LLVM dependent features if both everything is
>> present.
> It seems to be a bit more complicated:
> https://lowlevelbits.org/building-an-llvm-based-tool.-lessons-learned/
Please have a look at:
https://lists.rtems.org/pipermail/devel/2019-December/056517.html
I was able to build it on Debian 10:
Checking for library LLVM                : yes
sh at gcc68:~/rtems-tools$ ./build/trace/rtems-record-lttng --help
./build/trace/rtems-record-lttng [--host=HOST] [--port=PORT]
[--limit=LIMIT] [--elf=ELF] [INPUT-FILE]
Mandatory arguments to long options are mandatory for short options too.
   -h, --help                 print this help text
   -H, --host=HOST            the host IPv4 address of the record server
   -p, --port=PORT            the TCP port of the record server
   -l, --limit=LIMIT          limit in bytes to process
   -e, --elf=ELF              the ELF executable file
   INPUT-FILE                 the input file
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
