RTEMS Release Snapshot: 5.0.0-m1912 (05 Dec 2019)
Sebastian Huber
Tue Dec 17 06:46:47 UTC 2019
On 17/12/2019 07:31, Sebastian Huber wrote:
> On 16/12/2019 23:34, Michael Davidsaver wrote:
>> On 12/4/19 8:58 PM, chrisj at rtems.org wrote:
>>> RTEMS Release Build - 5.0.0-m1912
>>> RTEMS 5 Release snapshot m1912 is avaliable for testing.
>>> It can be found at:
>>> https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m1912
>>> Please test and report any issues to the user at rtems.org or
>>> devel at rtems.org
>>> mailing lists or please raise a ticket.
>>> If you are part of the RTEMS testing program please build on your
>>> preferred
>>> host posting build and BSP test results to build at rtems.org.
>>> This is a development release and may have errors and be unstable.
>>> Thanks
>>> Chris
>> Building on a Debian 10 host I get a link error in the rtems-tools
>> package involving LLVM.
>> It looks like the build is using the host LLVM (deb llvm-dev
>> 1:7.0-47). Is this supposed to
>> be the case?
> Thanks for testing the snapshot. I tried to build the rtems-tools on a
> Debian 10 of the GCC compile farm (gcc68), but it seems the LLVM
> development packages are not installed:
> ./waf configure
> Setting top to : /home/sh/rtems-tools
> Setting out to : /home/sh/rtems-tools/build
> Version : 5.429b74725885 (5)
> Checking for program 'python' : /usr/bin/python
> Checking for python version >= 2.6.6 : 2.7.16
> Checking for program 'python2' : /usr/bin/python2
> Checking for program 'python3' : /usr/bin/python3
> Checking for 'gcc' (C compiler) : /usr/bin/gcc
> Checking for 'g++' (C++ compiler) : /usr/bin/g++
> Checking for header alloca.h : yes
> Checking for header fcntl.h : yes
> Checking for header process.h : not found
> Checking for header stdlib.h : yes
> Checking for header string.h : yes
> Checking for header strings.h : yes
> Checking for header sys/file.h : yes
> Checking for header sys/stat.h : yes
> Checking for header sys/time.h : yes
> Checking for header sys/types.h : yes
> Checking for header sys/wait.h : yes
> Checking for header unistd.h : yes
> Checking for header vfork.h : not found
> Checking for getrusage : yes
> Checking for program 'm4' : /usr/bin/m4
> Checking for kill : yes
> Checking for strnlen : yes
> Checking for fopen64 : no
> Checking for stat64 : no
> Checking for library LLVM : not found
> Checking for header llvm/DebugInfo/Symbolize/Symbolize.h : not found
> Checking for library ws2_32 : not found
> Which packages did you install?
>>> $ ../source-builder/sb-set-builder --prefix $HOME/source/rtems/usr
>>> --rtems-bsp i386/pc386 5/rtems-i386
>> omitting many (I think) unimportant downloading, building, cleaning lines
>>> download:
>>> https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m1912/sources/autoconf-2.69.tar.gz
>>> -> sources/autoconf-2.69.tar.gz
>>> download:
>>> https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m1912/sources/automake-1.12.6.tar.gz
>>> -> sources/automake-1.12.6.tar.gz
>>> download:
>>> https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m1912/sources/automake-1.12.6-b...<see
>>> log> -> patches/automake-1.12.6-bugzilla.redhat.com-1239379.diff
>>> download:
>>> https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m1912/sources/expat-2.1.0.tar.gz
>>> -> sources/expat-2.1.0.tar.gz
>>> download:
>>> https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m1912/sources/gdb-8.3.tar.xz
>>> -> sources/gdb-8.3.tar.xz
>>> download:
>>> https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m1912/sources/binutils-2.33.1.tar.bz2
>>> -> sources/binutils-2.33.1.tar.bz2
>>> download:
>>> https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m1912/sources/gcc-7.5.0.tar.xz
>>> -> sources/gcc-7.5.0.tar.xz
>>> download:
>>> https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m1912/sources/newlib-d14714c69.tar.gz
>>> -> sources/newlib-d14714c69.tar.gz
>>> download:
>>> https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m1912/sources/isl-0.16.1.tar.bz2
>>> -> sources/isl-0.16.1.tar.bz2
>>> download:
>>> https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m1912/sources/mpfr-3.1.4.tar.bz2
>>> -> sources/mpfr-3.1.4.tar.bz2
>>> download:
>>> https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m1912/sources/mpc-1.0.3.tar.gz
>>> -> sources/mpc-1.0.3.tar.gz
>>> download:
>>> https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m1912/sources/gmp-6.1.0.tar.bz2
>>> -> sources/gmp-6.1.0.tar.bz2
>>> download:
>>> https://ftp.rtems.org/pub/rtems/releases/5/5.0.0/5.0.0-m1912/sources/rtems-tools-5.0.0-m1912.tar.xz
>>> -> sources/rtems-tools-5.0.0-m1912.tar.xz
>>> building: rtems-tools-5.0.0-m1912-1
>>> error: building rtems-tools-5.0.0-m1912-1
>> From the resulting rsb-report-rtems-tools-5.0.0-m1912-1.txt:
>>> Checking for header llvm/DebugInfo/Symbolize/Symbolize.h : yes
> It seems you have the header files, but no library was found. Maybe we
> should only build the LLVM dependent features if both everything is
> present.
It seems to be a bit more complicated:
https://lowlevelbits.org/building-an-llvm-based-tool.-lessons-learned/
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
