[EXTERNAL] Python.h
Oyake, Amalaye (US 386M) amalaye.oyake at jpl.nasa.gov
Tue Dec 17 18:29:23 UTC 2019
Install python-dev and python3-dev and retry.
* Amalaye Oyake, NASA / Jet Propulsion Laboratory.  */\  *
* Jet Propulsion Laboratory, Pasadena               *||  *
* CA                                           l    /||\ *
From: users <users-bounces at rtems.org> on behalf of "Dudley, David" <dudleyd at frib.msu.edu>
Date: Tuesday, December 17, 2019 at 8:49 AM
To: "users at rtems.org" <users at rtems.org>
Subject: [EXTERNAL] Python.h
OK, trying to setup source builder using the ‘Quick Start’ in the documentation set.
Building on “Linux  4.9.0-9-amd64 #1 SMP Debian 4.9.168-1+deb9u5 (2019-08-11) x86_64 GNU/Linux”
Get down to “2.4. Install the Tool Suite”
Run the command “../source-builder/sb-set-builder --source-only-download 5/rtems-sparc”
It fails with
“config: tools/rtems-gdb-8.3-1.cfg
error: config error: gdb-common-1.cfg:99: "gdb: python: header file not found: python2.7/Python.h, please install"
Following instructions exactly, on fresh system, no go.
Ideas?
David Dudley
Controls Engineer III
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7133
Email: dudleyd at frib.msu.edu<mailto:dudleyd at frib.msu.edu>
[cid:image002.jpg at 01D07041.57B6D750]
URL: <http://lists.rtems.org/pipermail/users/attachments/20191217/e9a97718/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.rtems.org/pipermail/users/attachments/20191217/e9a97718/attachment-0001.jpg>
