Python.h
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Tue Dec 17 17:22:22 UTC 2019
On Tue, Dec 17, 2019 at 10:19 PM Dudley, David <dudleyd at frib.msu.edu> wrote:
> OK, trying to setup source builder using the ‘Quick Start’ in the
> documentation set.
> Building on “Linux  4.9.0-9-amd64 #1 SMP Debian 4.9.168-1+deb9u5
> (2019-08-11) x86_64 GNU/Linux”
> Get down to “2.4. Install the Tool Suite”
> Run the command “../source-builder/sb-set-builder --source-only-download
> 5/rtems-sparc”
> It fails with
> “config: tools/rtems-gdb-8.3-1.cfg
> error: config error: gdb-common-1.cfg:99: "gdb: python: header file not
> found: python2.7/Python.h, please install"
Seems like the python-dev package isn't installed properly.
please try `sudo apt-get install python-dev`
> Following instructions exactly, on fresh system, no go.
> Ideas?
> *David Dudley*
> Controls Engineer III
> *Facility for Rare Isotope Beams*
> Michigan State University
> 640 South Shaw Lane
> East Lansing, MI 48824-1321, USA
> Tel. 517-908-7133
> Email: dudleyd at frib.msu.edu
> *[image: cid:image002.jpg at 01D07041.57B6D750]*
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20191217/62761dc3/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20191217/62761dc3/attachment-0001.jpg>
