Can't run ticker sample on beatnik with the actual rtems-5 master
Heinz Junkes junkes at fhi-berlin.mpg.de
Thu Feb 28 08:53:22 UTC 2019
With the actual rtems-master I can not load anymore programs on beatnik board (MVME6100)
[junkes at h rtems-source-builder (master)]$ ls rtems/sources/
autoconf-2.69.tar.gz
automake-1.12.6.tar.gz
binutils-2.32.tar.bz2
expat-2.1.0.tar.gz
gcc-7.4.0.tar.xz
gdb-8.2.1.tar.xz
gmp-6.1.0.tar.bz2
isl-0.16.1.tar.bz2
mpc-1.0.3.tar.gz
mpfr-3.1.4.tar.bz2
newlib-1d35a003f.tar.gz
rtems-tools-551ce0825375a43bd4438713d7a49633eef922b5.tar.bz2
Boot code created with
powerpc-rtems5-objcopy -Obinary ticker.exe ticker.boot
-rwxr-xr-x  1 junkes  staff  219504 Feb 28 09:35 ticker.boot
On the MVME6100 :
MVME6100> tftpGet -c141.14.128.53 -s141.14.133.59 -m255.255.240.0 -a04000000 -fticker.boot
Network Loading from: /dev/enet0
Loading File: ticker.boot
Load Address: 04000000
Download Buffer Size = User Defined
Client IP Address      = 141.14.128.53
Server IP Address      = 141.14.133.59
Gateway IP Address     = 141.14.128.253
Subnet IP Address Mask = 255.255.240.0
Network File Load in Progress...
Bytes Received =&219504, Bytes Loaded =&219504
Bytes/Second   =&219504, Elapsed Time =1 Second(s)
MVME6100> netShut
/dev/-----------------------------------------
config addr is 0xf1000cf8
config data is 0xf1000cfc
Welcome to RTEMS rtems-5.0.0 (PowerPC/Generic (classic FPU)/beatnik)
CPU: MPC7457
Board Type: MVME6100-0163 (S/N E173D29)
Bus Clock Freq:   133333333 Hz
CPU Clock Freq:  1266666654 Hz
Memory:           536870912 bytes
Now BSP_mem_size = 0x1fe00000
Configuration.work_space_size = 104d0
Page table setup finished; will activate it NOW…
Here the board stucks … no more output ...
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20190228/5eb7cf13/attachment.bin>
