MPCI not returning memory
Thu Jan 31 12:55:34 UTC 2019
On 31/01/2019 13:41, Andres Monteverde wrote:
> Hi Sebastian, Thank you for your prompt response.
> > I don't think this is correct. If you call _MPCI_Send_request_packet(),
> > then the ownership of this packet is transferred to the implementation
> > of this function. With the shared memory driver, the packet is freed by
> > the receiver, see Shm_Free_envelope()."
> If you think that it's not correct, we can move the returning of the
> packet inside _MPCI_Send_request_packet() but the reason why we return
> the packet outside _MPCI_Send_request_packet() is because we were
> focalized in queue behaviour and a change inside
> _MPCI_Send_request_packet() is a broad solution with an unknown effect
> for the test.
> Regarding "the packet is freed by the receiver, see
> Shm_Free_envelope()", by looking at the code and running the code step
> by step with jtag, the core0 (the owner of the queue) does not return
> the packet in any case.
> The core0 MPCI handler for the receive request is:
> _Message_queue_MP_Process_packet()
> case MESSAGE_QUEUE_MP_RECEIVE_REQUEST:
>       the_packet->Prefix.return_code = rtems_message_queue_receive(
>         the_packet->Prefix.id,
>         the_packet->Buffer.buffer,
>         &the_packet->size,
>         the_packet->option_set,
>         the_packet->Prefix.timeout
>       if ( the_packet->Prefix.return_code != RTEMS_PROXY_BLOCKING )
>         _Message_queue_MP_Send_response_packet(
>           MESSAGE_QUEUE_MP_RECEIVE_RESPONSE,
>           _Thread_Executing
>       break;
> The core1 MPCI handler for the receive response is:
> case MESSAGE_QUEUE_MP_RECEIVE_RESPONSE:
>       the_thread = _MPCI_Process_response( the_packet_prefix );
>       if (the_packet->Prefix.return_code == RTEMS_SUCCESSFUL) {
>         *(size_t *) the_thread->Wait.return_argument =
>            the_packet->size;
>         _CORE_message_queue_Copy_buffer(
> the_thread->Wait.return_argument_second.mutable_object,
>           the_packet->size
>       _MPCI_Return_packet( the_packet_prefix );
>       break;
> As far as i understand is the core 1 who frees the packet.
Yes, this is also my understanding.
> And in case of a timeout waiting at the queue, there is no response at
> all from core 0 so there's no return for the allocated packet nor the
> proxy.
These are probably two independent problems.
Core 1 must still receive this packet at some time and free it.
The lost proxy in case of a timeout is another issue.
I don't have time to look into the details at the moment.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
