Floating point support in ARM926ejs
Amarnath MB amarnath.mb at mistralsolutions.com
Fri Jan 4 12:56:47 UTC 2019
Hi,
Tried building sample application using Makefile.inc from the BSP installed
path,
there I'm able to get %f values properly (*Data : **1.123400*).
*Thank you & Regards,*
*Amarnath MB *
On Fri, Jan 4, 2019 at 3:49 PM Amarnath MB <amarnath.mb at mistralsolutions.com>
wrote:
> Hi,
> I have made a copy of hello sample and added my testcodes to it.
> I have also added '#define CONFIGURE_INIT_TASK_ATTRIBUTES
> RTEMS_FLOATING_POINT'
> before #include <rtems/confdefs.h>
> *Amarnath MB*
> On Fri, Jan 4, 2019 at 3:44 PM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 04/01/2019 11:08, Amarnath MB wrote:
>> > Currently, I'm facing an issue with floating point values, in my test
>> > Init.c file I have added a simple printf statement like below,
>> > *float data = 1.234;
>> > printf("Data : %f\n", data);*
>> > After loading the test executable, I'm getting the print as '*Data :
>> > %f*' in the console.
>> Do you use your own build system or did you modify the samples? In the
>> RTEMS test suite some output function like printf() are wrapped by the
>> linker to an alternative implementation without floating point support.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/users/attachments/20190104/9cca6600/attachment-0002.html>
