RTEMS not compiling with -mfloat-abi=hard in ARM926ejs
Amarnath MB
amarnath.mb at mistralsolutions.com
Wed Jan 9 06:06:39 UTC 2019
Hi Chris Johns,
I have configured the BSP with --target=arm-rtems5 --enable-rtemsbsp=socV1
--enable-maintainer-mode
--disable-networking --enable-posix, since --enable-tests is not used only
testsuites/samples are built.
I'm getting "configure: error: C compiler cannot create executables" during
BSP build (make RTEMS_BSP=socV1).
*Thank you & Regards,*
*Amarnath MB*
<http://www.mistralsolutions.com>
On Wed, Jan 9, 2019 at 7:11 AM Chris Johns <chrisj at rtems.org> wrote:
> On 9/1/19 3:41 am, Amarnath MB wrote:
> > What do you meant by dynamic loading tests?
> The tests under 'testsuites/libtests' for tests 'dl0*', for example dl01.
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20190109/8f46b350/attachment-0002.html>
