RTEMS not compiling with -mfloat-abi=hard in ARM926ejs
Amarnath MB
amarnath.mb at mistralsolutions.com
Wed Jan 9 13:11:42 UTC 2019
Hi All,
Finally, I was able to build BSP with hard float support using *CPU_CFLAGS
= -mcpu=arm926ej-s -mfpu=vfp -mfloat-abi=hard*. The issue was in using
*-mthumb* along with *-mfloat-abi=hard*, the compiler doesn't support this
combination
for
*-mcpu=arm926ej-s. *
Once again thanks for all your precious time.
*Thank you & Regards,*
*Amarnath MB*
On Wed, Jan 9, 2019 at 11:36 AM Amarnath MB <
amarnath.mb at mistralsolutions.com> wrote:
> Hi Chris Johns,
> I have configured the BSP with --target=arm-rtems5 --enable-rtemsbsp=socV1
> --enable-maintainer-mode
> --disable-networking --enable-posix, since --enable-tests is not used only
> testsuites/samples are built.
> I'm getting "configure: error: C compiler cannot create executables"
> during BSP build (make RTEMS_BSP=socV1).
> *Amarnath MB*
> <http://www.mistralsolutions.com>
> On Wed, Jan 9, 2019 at 7:11 AM Chris Johns <chrisj at rtems.org> wrote:
>> On 9/1/19 3:41 am, Amarnath MB wrote:
>> > What do you meant by dynamic loading tests?
>> The tests under 'testsuites/libtests' for tests 'dl0*', for example dl01.
>> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20190109/482d299f/attachment-0002.html>
