CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER macro issue
Michel Macena
mmacena.eng at gmail.com
Tue Jul 23 19:30:41 UTC 2019
Hi, I have compiled a test code for an ERC32 target board and loaded it
using gdb,
the code:
#include <bsp.h>
> #include <stdlib.h>
> #include <stdio.h>
> rtems_task Init(
> rtems_task_argument ignored
> uint16_t a=6;
> printf( "Hello World Michel\n" );
> printf( "numero: %d\n",a );
> #define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> //#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #define CONFIGURE_MAXIMUM_TASKS 1
> #define CONFIGURE_INIT
> #include <rtems/confdefs.h>
the board returned in the console:
Hello World Michel
> numero: 6
and GDB returns:
[Inferior 1 (Remote target) exited normally]
Everything as expected, but when I comment the #define
CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER line
and put #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER the board seems to
restart and gdb returns the following:
[Inferior 1 (Remote target) exited with code 020]
I know that I'm not using any clock depending function but shouldn't the
program work anyway ? Also I tried the clock function
rtems_clock_get_ticks_per_second()
to get the ticks and print it, but it didn't work.
Could someone explain wy this is happenning ? Also what is the code 020
return in GDB ?
I tried to find an error list for gdb but I couldn't find.
URL: <http://lists.rtems.org/pipermail/users/attachments/20190723/939e8623/attachment.html>
