CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER macro issue
Michel Macena
mmacena.eng at gmail.com
Fri Jul 26 20:13:17 UTC 2019
I tried the break at _Terminate, for a working program (with the #define
CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER macro) it worked and
returned
> Breakpoint 1, _Terminate (the_source=the_source at entry=INTERNAL_ERROR_CORE,
> the_error=the_error at entry=5)
> at
> /home/inpe/masters_project/src/rtems/c/src/../../cpukit/score/src/interr.c:34
but for a program with the #define
CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER macro it didn't work, just
returned the same message as before
> [Inferior 1 (Remote target) exited with code 020]
I don't know exactly what may be causing this and don't know how can I
track the issue ? any ideas ?
Em qua, 24 de jul de 2019 às 16:33, Joel Sherrill <joel at rtems.org> escreveu:
> On Wed, Jul 24, 2019, 1:58 PM Michel Macena <mmacena.eng at gmail.com> wrote:
>> Thanks for the answer.
>> Sorry for my ignorance but I can't see how is this related with my
>> problem. I didn't get the "Create bad task" problem. Also there is no
>> fatal error with code 20.
> No RTEMS bsp makes any effort to return an exit status to the invoking
> environment. What you are seeing gdb print is most likely random garbage.
> If you break at _Terminate, you will see why the program exited.
>> Em qua, 24 de jul de 2019 às 02:46, Sebastian Huber <
>> sebastian.huber at embedded-brains.de> escreveu:
>>> On 23/07/2019 21:30, Michel Macena wrote:
>>> > Hi, I have compiled a test code for an ERC32 target board and loaded
>>> it
>>> > using gdb,
>>> > the code:
>>> > #include <bsp.h>
>>> > #include <stdlib.h>
>>> > #include <stdio.h>
>>> > rtems_task Init(
>>> > rtems_task_argument ignored
>>> > uint16_t a=6;
>>> > printf( "Hello World Michel\n" );
>>> > printf( "numero: %d\n",a );
>>> Please have a look at the INTERNAL_ERROR_THREAD_EXITTED fatal error
>>> description:
>>> https://docs.rtems.org/branches/master/c-user/fatal_error.html#internal-error-codes
>>> If you use GDB, then always set a break point to _Terminate. It will hit
>>> if the application terminated.
>>> Sebastian Huber, embedded brains GmbH
>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>> Phone : +49 89 189 47 41-16
>>> Fax : +49 89 189 47 41-09
>>> E-Mail : sebastian.huber at embedded-brains.de
>>> PGP : Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20190726/a9c3d5e0/attachment-0002.html>
