CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER macro issue
Wed Jul 24 19:33:38 UTC 2019
On Wed, Jul 24, 2019, 1:58 PM Michel Macena <mmacena.eng at gmail.com> wrote:
> Thanks for the answer.
> Sorry for my ignorance but I can't see how is this related with my
> problem.  I didn't get the "Create bad task" problem. Also there is no
> fatal error with code 20.
No RTEMS bsp makes any effort to return an exit status to the invoking
environment. What you are seeing gdb print is most likely random garbage.
If you break at _Terminate, you will see why the program exited.
> Em qua, 24 de jul de 2019 às 02:46, Sebastian Huber <
> sebastian.huber at embedded-brains.de> escreveu:
>> On 23/07/2019 21:30, Michel Macena wrote:
>> > Hi, I have compiled a test code for an ERC32 target board and loaded it
>> > using gdb,
>> > the code:
>> >     #include <bsp.h>
>> >     #include <stdlib.h>
>> >     #include <stdio.h>
>> >     rtems_task Init(
>> >        rtems_task_argument ignored
>> >          uint16_t a=6;
>> >          printf( "Hello World Michel\n" );
>> >          printf( "numero: %d\n",a );
>> Please have a look at the INTERNAL_ERROR_THREAD_EXITTED fatal error
>> description:
>> https://docs.rtems.org/branches/master/c-user/fatal_error.html#internal-error-codes
>> If you use GDB, then always set a break point to _Terminate. It will hit
>> if the application terminated.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20190724/15c9dc81/attachment-0002.html>
