CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER macro issue
Michel Macena
mmacena.eng at gmail.com
Sat Jul 27 21:42:21 UTC 2019
Yes it is on real hardware, it is a real ERC32 chipset. The board was
developed by Tharsys, but the
company does not exist anymore. I'm not sure but in some way the hardware
does not
like the CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER macro.
I've been using GDB like this:
> sparc-rtems5-gdb
> /home/inpe/rtems_exemplos/compile_test/hello_test/hello_exp.exe
> set serial baud 19200
> target extended-remote /dev/ttyS0
> load
> continue
When I use the CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER macro, the
board returns all
prints properly at the serial port.
Em sex, 26 de jul de 2019 às 17:47, Joel Sherrill <joel at rtems.org> escreveu:
> On Fri, Jul 26, 2019 at 3:13 PM Michel Macena <mmacena.eng at gmail.com>
> wrote:
>> I tried the break at _Terminate, for a working program (with the #define
>> CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER macro) it worked and
>> returned
>>> Breakpoint 1, _Terminate (the_source=the_source at entry=INTERNAL_ERROR_CORE,
>>> the_error=the_error at entry=5)
>>> at
>>> /home/inpe/masters_project/src/rtems/c/src/../../cpukit/score/src/interr.c:34
>> but for a program with the #define
>> CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER macro it didn't work, just
>> returned the same message as before
>>> [Inferior 1 (Remote target) exited with code 020]
>> I don't know exactly what may be causing this and don't know how can I
>> track the issue ? any ideas ?
> Is this on real hardware? I re-read the first message and wondered about
> that.
> But looking at the code again, it is a Classic API Init task and falling
> off the bottom. This should be a fatal error.
> I suppose it is possible that the program has exited and the tick ISR is
> occurring after RTEMS has terminated. But it still should be hitting the
> _Terminate symbol.
> --joel
>> Em qua, 24 de jul de 2019 às 16:33, Joel Sherrill <joel at rtems.org>
>> escreveu:
>>> On Wed, Jul 24, 2019, 1:58 PM Michel Macena <mmacena.eng at gmail.com>
>>> wrote:
>>>> Thanks for the answer.
>>>> Sorry for my ignorance but I can't see how is this related with my
>>>> problem. I didn't get the "Create bad task" problem. Also there is no
>>>> fatal error with code 20.
>>> No RTEMS bsp makes any effort to return an exit status to the invoking
>>> environment. What you are seeing gdb print is most likely random garbage.
>>> If you break at _Terminate, you will see why the program exited.
>>>> Em qua, 24 de jul de 2019 às 02:46, Sebastian Huber <
>>>> sebastian.huber at embedded-brains.de> escreveu:
>>>>> On 23/07/2019 21:30, Michel Macena wrote:
>>>>> > Hi, I have compiled a test code for an ERC32 target board and loaded
>>>>> it
>>>>> > using gdb,
>>>>> > the code:
>>>>> > #include <bsp.h>
>>>>> > #include <stdlib.h>
>>>>> > #include <stdio.h>
>>>>> > rtems_task Init(
>>>>> > rtems_task_argument ignored
>>>>> > uint16_t a=6;
>>>>> > printf( "Hello World Michel\n" );
>>>>> > printf( "numero: %d\n",a );
>>>>> Please have a look at the INTERNAL_ERROR_THREAD_EXITTED fatal error
>>>>> description:
>>>>> https://docs.rtems.org/branches/master/c-user/fatal_error.html#internal-error-codes
>>>>> If you use GDB, then always set a break point to _Terminate. It will
>>>>> hit
>>>>> if the application terminated.
>>>>> Sebastian Huber, embedded brains GmbH
>>>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>>>> Phone : +49 89 189 47 41-16
>>>>> Fax : +49 89 189 47 41-09
>>>>> E-Mail : sebastian.huber at embedded-brains.de
>>>>> PGP : Public key available on request.
>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>>> _______________________________________________
>>>> users mailing list
>>>> users at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20190727/b881a3f9/attachment-0002.html>
