stm32 external SRAM
Jython
googcheng at gmail.com
Mon Jun 17 01:05:17 UTC 2019
STM32:
112KB at 2000 0000
16KB at 2001 C000
external sram : 1MB at 0x68000000
does MEMORY layout support RAM2?
On Fri, Jun 14, 2019 at 10:13 PM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> If you have already added the chip and it is initialized during startup,
> you most likely have to add a section for it in your linker command
> file. Depending on where your internal RAM is located and where the
> external one is: If they are continuous that can be enough.
> Best regards
> Christian
> On 14/06/2019 04:42, Jython wrote:
> > we have added 1M ram by FSMC, and want to manage it by system malloc
> > controler
> > On Fri, Jun 14, 2019 at 10:26 AM Mr. Andrei Chichak <groups at chichak.ca
> > <mailto:groups at chichak.ca>> wrote:
> > A 407 doesn’t normally have external RAM.
> > ARMs have flash at 0 and the 407 has RAM at 0x2000 0000 as you
> > discussed earlier.
> > If you want to work with external flash or RAM, you have to set up
> > the FSMC or FMC to support it, but that isn’t a part of the dev
> > board that Sebastian used for the BSP port.
> > The external memory is going to be very specific to your board.
> > Which board are you working with?
> > A
> > > On 2019-June-13, at 06:23, Christian Mauderer
> > <christian.mauderer at embedded-brains.de
> > <mailto:christian.mauderer at embedded-brains.de>> wrote:
> > > On 05/06/2019 02:55, Jython wrote:
> > >> Hello!
> > >> 2. In the normal (non-debugging) case, the linker script still
> > >> places the
> > >> .text section near zero, but places the start of the .data and
> > .bss
> > >> sections at the start location of the MPC555's internal RAM.
> The
> > >> system startup code then configures the external RAM just
> > after the
> > >> internal RAM in memory, forming one large block from the two
> RAM
> > >> devices.
> > >> from https://devel.rtems.org/wiki/TBR/BSP/Ss555
> > >> but i dont know how to configure the external RAM just after the
> > >> internal RAM in memory?
> > >> hope you could give me some guide!
> > > Hello Jython,
> > > the documentation you linked is for an MPC. But your subject line
> > > mentions an STM32. What controller / BSP are you using?
> > > Best regards
> > > Christian Mauderer
> > > embedded brains GmbH
> > > Herr Christian Mauderer
> > > Dornierstr. 4
> > > D-82178 Puchheim
> > > Germany
> > > email: christian.mauderer at embedded-brains.de
> > > Phone: +49-89-18 94 741 - 18
> > > Fax: +49-89-18 94 741 - 08
> > > PGP: Public key available on request.
> > > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des
> EHUG.
> > > _______________________________________________
> > > users mailing list
> > > users at rtems.org <mailto:users at rtems.org>
> > > http://lists.rtems.org/mailman/listinfo/users
> > users mailing list
> > users at rtems.org
> Dornierstr. 4
> D-82178 Puchheim
> Germany
URL: <http://lists.rtems.org/pipermail/users/attachments/20190617/3c76a9b4/attachment.html>
