stm32f4 __wfi
Christian Mauderer christian.mauderer at embedded-brains.de
Fri Jun 21 11:09:00 UTC 2019
On 21/06/2019 11:53, Jython wrote:
> i got it ,  i have coded some low power applications with stm32cube last
> year,
> may i just want to know more about the sleep and why it does not stop by
> EXTI , maybe i need to rewrite sleep function ?
`sleep()` just suspends your current task. So you will reach (after a
task switch) the idle loop.
> On Fri, Jun 21, 2019 at 3:16 PM Christian Mauderer
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>     On 21/06/2019 02:58, Jython wrote:
>     > handler https://gist.github.com/goog/7bf5ec55139a3ed43e36be5b2eee318b
>     There are some things that I would strongly discourage in that interrupt
>     handler (printk as long as it is not only a temporary debug output,
>     delay, ...) but it shouldn't be the problem. I assume that you already
>     checked, that you are testing for the right flag in the first if. So I
>     would expect that you get your debug output if your interrupt occurs.
>     > the main loop code
>     > https://gist.github.com/goog/d83786e0eb2c97ad3126ded1987b5078
>     Same again: Some details but nothing that I would see as a cause for
>     your problem.
>     > when i pressed key, printf("loop begin\n"); does not print immediately
>     > so the sleep function does not break
>     Note that printf is a interrupt driven print. So if you have problems
>     with _some_ interrupts not waking up your device you might not get an
>     output or maybe only a "l".
>     I agree with the mail from "groups chichak.ca <http://chichak.ca>".
>     It's a problem that is
>     very chip specific and not really a RTEMS specific one. So it might
>     would be a good idea to search for "STM32 not waking up" in the ST
>     forums.
>     > On Thu, Jun 20, 2019 at 10:47 PM Christian Mauderer
>     <list at c-mauderer.de <mailto:list at c-mauderer.de>
>     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
>     >     On 20/06/2019 16:43, Jython wrote:
>     >     > sleep function at the ending of loop, the loop did not begin
>     >     intermediate
>     >     So just that I understand it correctly: Your have a loop in a
>     task that
>     >     sends your processor to sleep at the end of the loop. Then you
>     wake up
>     >     the processor via an interrupt and the interrupt handler is
>     executed.
>     >     But you don't reach the loop again?
>     >     I think I remember some discussion where you wanted to put a
>     sleep into
>     >     your idle loop? Maybe you have a double sleep?
>     >     > On Thursday, June 20, 2019, Christian Mauderer
>     >     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
>     >     >     On 20/06/2019 13:25, Jython wrote:
>     >     >     > do have service routine,  handler can printk log,
>     >     SLEEPONEXIT is 0
>     >     >     So your handler is called? But it seems that the processor
>     >     wakes up
>     >     >     then. How does the "won't stop sleep mode" look like?
>     >     >     > On Thu, Jun 20, 2019 at 5:19 PM Christian Mauderer
>     >     >     <list at c-mauderer.de <mailto:list at c-mauderer.de>
>     >     >     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>> wrote:
>     >     >     >     On 20/06/2019 10:57, Jython wrote:
>     >     >     >     > a GPIO EXTI line,
>     >     >     >     > rtems idle phrase called __wfi, does it make
>     stm32 enter
>     >     >     standby mode?
>     >     >     >     > so key can not wake up it from sleep function
>     >     >     >     Please take a look at the reference manual of your
>     chip.
>     >     Most
>     >     >     likely
>     >     >     >     it's "RM0090 Rev 18" but make sure that's the
>     right part
>     >     number:
>      https://www.st.com/resource/en/reference_manual/dm00031020.pdf
>      <https://www.st.com/resource/en/reference_manual/dm00031020.pdf>
>     >     >     >     On page 127 there is a description of "Entering
>     >     low-power mode":
>     >     >     >         "Low-power modes are entered by the MCU by
>     executing the
>     >     >     WFI (Wait
>     >     >     >         For Interrupt), or WFE (Wait for Event)
>     instructions, or
>     >     >     when the
>     >     >     >         SLEEPONEXIT bit in the Cortex ®-M4 with FPU System
>     >     Control
>     >     >     >         register is set on Return from ISR."
>     >     >     >     There is also a description for "Exiting low-power
>     >     mode". For
>     >     >     WFI "any
>     >     >     >     peripheral interrupt acknowledged by the NVIC can wake
>     >     up the
>     >     >     device."
>     >     >     >     So your interrupt has to be set up.
>     >     >     >     Your code seems to enable the interrupt. But have you
>     >     registered a
>     >     >     >     interrupt service routine? Otherwise you might get
>     problems
>     >     >     with an
>     >     >     >     unhandled interrupt on wakeup.
>     >     >     >     I only skimmed through the power controller
>     chapter. But it
>     >     >     seems that
>     >     >     >     if you have SLEEPDEEP bit set, you will enter a deeper
>     >     sleep mode
>     >     >     >     where peripheral clocks can be disabled. In that
>     state it's
>     >     >     possible
>     >     >     >     that only special pins (like the WKUP) can wake up the
>     >     processor
>     >     >     >     again. Please have a detailed look at that chapter to
>     >     find out all
>     >     >     >     traps.
>     >     >     >     Best regards
>     >     >     >     Christian
>     >     >     >     >     void keys_init()
>     >     >     >     >         // config gpio
>     >     >     >     >     stm32f4_gpio_set_config(&io_key1);  // PA12
>     >     >     >     >     stm32f4_gpio_set_config(&io_key2);
>     >     >     >     >         stm32f4_gpio_set_config(&io_key3);
>     >     >     >     >     stm32f4_gpio_set_config(&io_key4);
>     >     >     >     >         //  SYSCFGEN and exit map
>     >     >     >     >     (*(uint32_t*)0x40023844) |= 1<<14;
>     >     >     >     >         SYSCFG_EXTICR3 = 0;
>     >     >     >     >         SYSCFG_EXTICR4 = 0;
>     >     >     >     >         // EXIT INIT
>     >     >     >     >     EXTI_IMR |= (1<<12);
>     >     >     >     >     EXTI_RTSR |= (1<<12);
>     >     >     >     >         EXTI_IMR |= (1<<11);
>     >     >     >     >     EXTI_RTSR |= (1<<11);
>     >     >     >     >         EXTI_IMR |= (1<<10);
>     >     >     >     >     EXTI_RTSR |= (1<<10);
>     >     >     >     >         EXTI_IMR |= (1<<9);
>     >     >     >     >     EXTI_RTSR |= (1<<9);
>     >     >     >     >         //NVIC_Init
>     >     >     >     >         //NVIC it group2
>     >     >     >     >     SCB_AIRCR = 0x05FA0000 | 0x500;
>     >     >     >     >     // ip Interrupt priority register x
>     >     >     >     >     //(*(volatile uint8_t*)0xE000E417) = 0xe0;  //23
>     >     >     >     >         //(*(volatile uint8_t*)0xE000E428) =
>     0xe0;  // 40
>     >     >     >     >         (*(volatile uint8_t*)0xE000E417) =
>     0x50;  //23
>     >     >     >     >         (*(volatile uint8_t*)0xE000E428) =
>     0x50;  // 40
>     >     >     >     >     // 23 40 Interrupt set-enable register x
>     (NVIC_ISERx)
>     >     >     >     >         // nvic enable interrupter number
>     >     >     >     >         // 0xE000E100
>     >     >     >     >         (*(volatile uint32_t*)0xE000E100) |=
>     (1<<23);
>     >     >     >     >         (*(volatile uint32_t *)0xE000E104) |= (1<<
>     >     (40%32));
>     >     >     >     > On Thu, Jun 20, 2019 at 4:05 PM Christian Mauderer
>     >     >     >     <list at c-mauderer.de <mailto:list at c-mauderer.de>
>     >     >     >     > <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de> <mailto:list at c-mauderer.de
>     <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>>>> wrote:
>     >     >     >     >     On 20/06/2019 05:28, Jython wrote:
>     >     >     >     >     > hi, it seems that exit key interrupt won't
>     stop
>     >     sleep
>     >     >     mode, why?
>     >     >     >     >     What do you mean by "exit key interrupt"? I
>     don't
>     >     know the
>     >     >     >     STM32F4 that
>     >     >     >     >     well. So please give some more details.
>     >     >     >     >     I would expect that either only specific
>     interrupt
>     >     >     sources can
>     >     >     >     wake up
>     >     >     >     >     the processor from a deep sleep mode or that
>     you can
>     >     >     configure
>     >     >     >     which
>     >     >     >     >     peripherals are still active. If your "exit key"
>     >     is a GPIO
>     >     >     >     line with
>     >     >     >     >     interrupt capability you should have a look at
>     >     whether the
>     >     >     >     module is
>     >     >     >     >     still active.
>     >     >     >     >     Best regards
>     >     >     >     >     Christian
>     >     >     >     >     _______________________________________________
>     >     >     >     >     users mailing list
>     >     >     >     >     users at rtems.org <mailto:users at rtems.org>
>     <mailto:users at rtems.org <mailto:users at rtems.org>>
>     <mailto:users at rtems.org <mailto:users at rtems.org>>>
>     >     >     <mailto:users at rtems.org <mailto:users at rtems.org>
>     <mailto:users at rtems.org <mailto:users at rtems.org>>>>
>     >     >     >     <mailto:users at rtems.org <mailto:users at rtems.org>
>     <mailto:users at rtems.org <mailto:users at rtems.org>>>>>
>     >     >     >     >     http://lists.rtems.org/mailman/listinfo/users
>     >     >     <http://lists.rtems.org/mailman/listinfo/users>
>     > users mailing list
>     embedded brains GmbH
>     Herr Christian Mauderer
>     Dornierstr. 4
>     D-82178 Puchheim
>     Germany
>     email: christian.mauderer at embedded-brains.de
>     Phone: +49-89-18 94 741 - 18
>     Fax:   +49-89-18 94 741 - 08
>     PGP: Public key available on request.
>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
Dornierstr. 4
D-82178 Puchheim
Germany
