Beaglebone help needed
Wed Mar 6 11:11:16 UTC 2019
On 6/3/19 6:07 pm, Sarvesh Patkar wrote:
> Hey everyone,
> I went through the quick start guide and could build the Hello World for the
> sparc/erc32 target.
> I would like to contribute to RTEMS in adding functionality and maybe, writing
> BSPs for some development boards that I have. I started with Beaglebone Black.
Welcome and this sounds great.
> There are a few questions that I have as follows.
>  1. There is a build set called beagle.bset that is defined in Ben Gras's Github
>     repository (https://github.com/bengras/rtems-source-builder/tree/beagle),
>     that hasn't been merged into the main rtems-source-builder git repository.
>     Is there a way to know if that will happen?
It could be if it is updated so it can be merged to master.
>  2. The instructions given in the blog link mentioned on the
>     ticket https://devel.rtems.org/ticket/2891 do not seem to work because the
>     link for fetching the mpc library is broken/wrong. (I corrected the link
>     locally and the sb-set-builder seems to go beyond that error) I think this
>     change was made already in all branches in the official repository but not
>     Ben's. I see another error while running sb-set-builder during compilation
>     of ubsan.c (gcc-6.3.0) as follows. Is there a patch for this that I can
>     apply to fix my local clone of the rsb ?
Are you using the master version of the RSB from git.rtems.org?
> ../../gcc-6.3.0/gcc/ubsan.c: In function 'bool ubsan_use_new_style_p(location_t)':
> ../../gcc-6.3.0/gcc/ubsan.c:1474:23: error: ISO C++ forbids comparison between
> pointer and integer [-fpermissive]
>        || xloc.file == '\0' || xloc.file[0] == '\xff'
> Any help in this matter is highly appreciated. If not the Beaglebone black, I
> have some ARM Cortex-M boards that I would like to work towards.
> Thank you for the help.
> Regards,
> Sarvesh
> users mailing list
> users at rtems.org
