RTEMS scheduler bug ?
Fri Mar 29 13:36:25 UTC 2019
On 29/03/2019 14:31, Catalin Demergian wrote:
> Sure, I will build and try.
> Is _ISR_Get_level() something CPU-specific ? I mean we use it to
> figure out if interrupts are enabled or not, right ?
> forgot to say, I use a STM32H7. Does _ISR_Get_level work on it ?
I would run test
testsuites/sptests/sp37
to figure out if it works.
> Also, I thought the scheduler code runs with interrupts enabled, I
> mean doesn't it use the tick interrupt itself ?
> How does that work on RTEMS ?
Some critical sections of the scheduler are protected by disabled
interrupts.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
