throwing std::runtime on PC BSP fails
Joel Sherrill
joel at rtems.org
Thu Mar 14 20:11:59 UTC 2019
On Thu, Mar 14, 2019 at 3:06 PM Heinz Junkes <junkes at fhi-berlin.mpg.de>
wrote:
> The porting of Epics-7 to RTEMS 5 is almost finished.
> To run our tests we use Travis-Ci where we run qemu-i386.
> (I couldn't find a suitable emulator for the PowerPC, beatnik board. I do
> the tests on the hardware.)
> Unfortunately our tests get stuck with one of the tests. This is because
> >> https://devel.rtems.org/ticket/2830
> Are there any chance that this will be fixed soon?
I don't think anyone is actively working on it. So doubtful.
What CPU model are you compiling for? I suspect the atomics may vary by CPU
model.
FWIW The ticket needs a test case.
This is a good example of someone needing funding to investigate. And
the ticket owner indicates that.
--joel
> Danke,
> Heinz
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20190314/8e55dcf3/attachment-0002.html>
