Reminder: Public RTEMS SMP space profile review closes 15th May
Sebastian Huber
Fri May 10 04:58:17 UTC 2019
Hello,
the public review closes on 15th May (next week).
You can find the survey results and our space profile proposal in the
document below:
https://ftp.rtems.org/pub/rtems/people/sebh/tn-space-profile-r1-12042019.pdf
sha512sum tn-space-profile-r1-12042019.pdf
4cf83ad5eff7638d6d067e0119263a41bddb58193bb9f1119c28066ece94b056fafbd08b3047d5311cda84735709a705f908bc2143ca87f67ccfaa8186eaf4a7
The space profile proposal sets the scope of an ongoing ESA activity and
is not related to the feature set of mainline RTEMS. Everyone is invited
to send comments with respect to the space profile proposal until 15th
May 2019. In particular, we would like to receive some feedback on the
open issues identified - it would be helpful for us to know your opinion.
A list of the open issues follows:
CLOCK_REALTIME
The survey results suggest that there is an interest in supporting
CLOCK_REALTIME. This clock must be specified first. It raises the question
how the time synchronization should be done (e.g. Network Time
Protocol)? How
is the leap second handling performed? How do you get the initial time at
system start?
Fatal Error Handling
The API for fatal error handling in mainline RTEMS and Edisoft RTEMS
Improvement diverged substantially. There are no plans to integrate the
Edisoft RTEMS Improvement fatal error handling support in mainline RTEMS.
IO Manager
Is this poorly designed API really used for device drivers in mission
critical
software? Which problem does it solve? Do you really want to use global
variables for the major and minor device numbers to access your drivers? Do
you really want to read and write to devices via a void pointer
interface with
absolutely no static type checking? This API offers no chance for static
analysis tools to produce anything useful.
Interrupt Controller Interface
The interrupt controller interface must be specified. This includes
interrupt
handler installation and removal, disabling and enabling of specific
interrupts, setting of interrupt priorities, etc.
GPIO Driver
The survey results suggest that some users would like to
have an GPIO driver included in the space profile. The interface and
feature
set of such a driver must be specified. GPIO drivers are available in
mainline
RTEMS based on the Gaisler driver manager.
MIL-STD-1553 Driver
have an MIL-STD-1553 driver included in the space profile. The
interface and feature
set of such a driver must be specified. MIL-STD-153 drivers are
available in mainline
RTEMS based on the Gaisler driver manager and also previous ESA activities.
UART Driver
have an UART driver included in the space profile. The interface and
feature
set of such a driver must be specified. The standard UART drivers of
RTEMS use
the Termios framework. This seems to be a bit too complex and
complicated for
the intended criticality category. Things to consider are the device
settings
(baud, bits per word, parity, stop bits), how to set them, flow control
yes/no/software/hardware, a potential line mode, timeout handling, character
conversion, buffering, interrupt or polled mode, DMA support, etc.
SpaceWire Driver
have an SpaceWire driver included in the space profile. The interface
and feature
set of such a driver must be specified. SpaceWire drivers are available
in mainline
Best regards,
Sebastian
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
