RTEMS_FATAL_SOURCE_EXCEPTION in RTEMS
Amarnath MB
amarnath.mb at mistralsolutions.com
Thu May 2 09:18:48 UTC 2019
Hi Christian,
As per your suggestion, i tried disabling global interrupt before my erase
call and enabling it afterwards. With this setup the test routine is
passing without giving exception. So i think, interrupt was the issue here.
Flash controller is implemented using the AHB to external SRAM interface in
the Cortex-M System Design Kit and there are no pins shared between RAM and
NOR Flash. We can't doubt that flash is blocking bus accesses for the RAM,
because the test executes fine in the uboot running from RAM.
You had mentioned there are a lot of possible reasons for a
RTEMS_FATAL_SOURCE_EXCEPTION, is it somewhere documented what all reasons
can cause this exception. Any references would be very much helpful.
Thank you once again for your prompt response, it really saved lot of our
time.
Below is the exception frame we got,
FYI, 0x0 - 0x007FFFFF is NOR Flash and 0x40000000 to 0x7FFFFFFF the RAM.
*** FATAL ***
fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION)
R0 = 0x00000040 R8 = 0x00100000
R1 = 0x00080000 R9 = 0x00000001
R2 = 0x00000048 R10 = 0x4010a3e8
R3 = 0x00000048 R11 = 0x4011737c
R4 = 0x00000a00 R12 = 0x00000000
R5 = 0x00000500 SP = 0x40100c40
R6 = 0x00000055 LR = 0x4000a36c
R7 = 0x000000aa PC = 0x003fde80
CPSR = 0x200000d2 VEC = 0x00000001
RTEMS version: 5.0.0.
RTEMS tools: 7.4.0 20181206 (RTEMS 5, RSB
40ae056f12e1cbe530f76a3ebd1e2ac745a888ef, Newlib
dc6e94551f09d3a983afd571478d63a09d6f66fa)
executing thread ID: 0x08a010002
executing thread name: Alpi
*Thank you & Regards,*
*Amarnath MB*
On Thu, May 2, 2019 at 12:49 AM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> ----- Ursprüngliche Mail -----
> > Von: "Amarnath MB" <amarnath.mb at mistralsolutions.com>
> > An: "Christian Mauderer" <christian.mauderer at embedded-brains.de>
> > CC: "RTEMS Users" <users at rtems.org>, "Ravi G Patil" <
> ravigp at mistralsolutions.com>, "Shekhar Suman Singh"
> > <shekhar.s at mistralsolutions.com>
> > Gesendet: Mittwoch, 1. Mai 2019 17:07:13
> > Betreff: Re: RTEMS_FATAL_SOURCE_EXCEPTION in RTEMS
> > Hi Christian,
> > Thanks for your quick response.
> > Our boot process is like, first u-boot will be loaded from the NOR flash
> > and then the uboot copies RTEMS application from NOR flash to the RAM.
> > After that RTEMS executes entirely from RAM.
> > How can i issue a global interrupt disable? Is it using *
> > rtems_interrupt_disable(0)*?
> > One more doubt, if i issue a global interrupt disable then will there be
> > chance that i can miss few clock ticks?
> > *Amarnath MB*
> Hello Amarnath,
> with a global interrupt lock, all kinds of events can be missed including
> clock ticks. Most should be processed just a little late but some
> interfaces might loose packets or data (depending on the data rate / flash
> access times). So if not necessary it's not a good solution.
> The rtems_interrupt_disable() function should be called with a level
> argument. See the example at
> https://docs.rtems.org/branches/master/c-user/interrupt_manager.html#rtems-interrupt-disable.
> Note that for SMP configurations, you might have to use other functions.
> But if your application runs entirely from RAM than the bus access
> shouldn't be the problem. So the interrupt might isn't the right guess.
> Do you have any more information on the exception and where it happens?
> Some output or a stack trace from a debugger?
> What kind of flash controller is used? Can it block bus accesses for the
> RAM? Does your RAM share pins with the flash?
> With kind regards
> Christian
> > On Wed, May 1, 2019 at 8:16 PM Christian Mauderer <
> >> > An: "RTEMS Users" <users at rtems.org>
> >> > CC: "Ravi G Patil" <ravigp at mistralsolutions.com>, "Shekhar Suman
> Singh"
> >> > Gesendet: Mittwoch, 1. Mai 2019 16:28:23
> >> > Betreff: RTEMS_FATAL_SOURCE_EXCEPTION in RTEMS
> >> > Hi All,
> >> > I'm developing RTEMS 5.00 BSP and device drivers for a custom
> ARM926EJ-S
> >> > core. I was successful in porting and building BSP for the ARM core.
> >> > We are facing a strange issue with the generic NOR flash driver we
> have
> >> > developed. Our device drivers are designed such that it can be used
> with
> >> > RTEMS as well as the bare metal programs.
> >> > Our driver is working fine in bare metal program (erase, read, write
> >> > everything), but when we use the driver with RTEMS application and
> issue
> >> an
> >> > erase call, then the application gives RTEMS_FATAL_SOURCE_EXCEPTION.
> >> > For testing driver in RTEMS, we have added each test routine as a
> custom
> >> > shell command using rtems_shell_add_cmd().
> >> > For your info we also tested the same driver with u-boot and it works
> >> > fines.
> >> > Can anyone guide me on this issue?
> >> > *Amarnath MB*
> >> Hello Amarnath,
> >> it's a little hard with the given information to tell you a concrete
> >> problem. There are a lot of possible reasons for a
> >> From your description, my guess would be some problem with an interrupt.
> >> Most U-Boot code avoids interrupts. I don't know about your bare metal
> >> application but maybe in some test application, you don't have too much
> >> interrupts too. In RTEMS you have most likely at least a periodic tick
> >> interrupt.
> >> Do you execute your code from the same flash or do you keep some data in
> >> the flash? In that case it could be an access error during a flash
> erase or
> >> write (for example caused by an interrupt). In that case you might have
> to
> >> do a global interrupt disable before you enter certain routines.
> >> Best regards
> >> Christian
> embedded brains GmbH
> Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax: +49-89-18 94 741 - 08
> PGP: Public key available on request.
URL: <http://lists.rtems.org/pipermail/users/attachments/20190502/ce25c02f/attachment-0002.html>
