RTEMS_FATAL_SOURCE_EXCEPTION in RTEMS
    Amarnath MB
    amarnath.mb at mistralsolutions.com
    Fri May  3 10:22:18 UTC 2019
Hi Christian,
Thank you for all your support.
I will debug on this issue and will keep you posted.
*Thank you & Regards,*
*Amarnath MB*
On Fri, May 3, 2019 at 2:34 PM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> ----- Ursprüngliche Mail -----
> > Von: "Amarnath MB" <amarnath.mb at mistralsolutions.com>
> > An: "Christian Mauderer" <christian.mauderer at embedded-brains.de>
> > CC: "RTEMS Users" <users at rtems.org>, "Ravi G Patil" <
> ravigp at mistralsolutions.com>, "Shekhar Suman Singh"
> > <shekhar.s at mistralsolutions.com>
> > Gesendet: Freitag, 3. Mai 2019 10:37:20
> > Betreff: Re: RTEMS_FATAL_SOURCE_EXCEPTION in RTEMS
> > Hi Christian,
> > Sorry for the formatting issue, from now onward i will follow like you
> > suggested.
> >>Hello Amarnath,
> >>just a note in front: Could you try to keep the '>' signs (some mail
> > programs show them as a solid line)
> >>at the front of the lines intact and don't use ones on your newly written
> > lines? Otherwise it's a little
> >>hard to see the answers. There's normally no strong formatting
> > requirements on this list (also we theoretically have a policy:
> >>https://devel.rtems.org/wiki/RTEMSMailingLists#Policies) but please try
> to
> > keep the mails readable.
> >>I tried to fix the indentation signs in my answer below. I hope that I
> > caught all your remarks.
> > Thanks.
> >>> Gesendet: Freitag, 3. Mai 2019 09:35:27
> >>Then it would be best to find the reason for the exception and avoid the
> > interrupt lock if possible.
> > We are discussing this issue with our FPGA team and hope to resolve it
> soon.
> >>>> > Flash controller is implemented using the AHB to external SRAM
> > interface
> >>>> in
> >>>> > the Cortex-M System Design Kit and there are no pins shared between
> > RAM
> >>>> and
> >>>> > NOR Flash.  We can't doubt that flash is blocking bus accesses for
> the
> >>>> RAM,
> >>>> > because the test executes fine in the uboot running from RAM.
> >>>> So it's a custom FPGA based design? Most likely your RAM and Flash
> >>>> controller are both connected to the same system bus (AHB in that
> > case). I
> >>>> don't know the modules you mentioned but you might want to take a look
> > at
> >>>> the documentation whether they lock the AHB or not.
> >>>  Yes its a custom FPGA based design. Sure, I will go through the
> >>> documentation.
> >>If the flash controller really blocks all other bus accesses (which would
> > be an odd design),
> >>you might can move the RAM and Flash to an independent bus or maybe add
> > some kind of bus bridge
> >>to separate the Flash. But I'm not that deep into the ARM blocks.
> > Our FPGA team has to see whether it is feasible.
> >>>> U-Boot most likely doesn't use interrupts. I assume you are waiting
> for
> > a
> >>>> flash operation to be finished in some busy wait loop there (polling a
> > flag
> >>>> or similar). That loop can be fully put into the processor cache (if
> you
> >>>> have one which is quite likely). So in your U-Boot test case, the
> > external
> >>>> RAM most likely isn't accessed during the flash operations. If you
> have
> > a
> >>>> problem
> >>>> with conflicting bus accesses you maybe only see them there if you
> > disable
> >>>> all caches.
> >>> You are correct, we are waiting in a loop polling the busy status of
> NOR
> >>> flash. Currently, the caches are enabled in both uboot and RTEMS.
> >>Maybe you can try to disable them in U-Boot and see whether your behavior
> > changes?
> >>It could be a bug in disguise if the U-Boot code only works due to
> caches.
> > These are
> >>quite nasty because they sometimes depend on the exact position of the
> > code. In most
> >>cases it works because the loop is in the cache but if for some reason
> the
> > processor
> >>has to load a new cache line for the loop it doesn't work. Really hard to
> > find because
> >>you can change something somewhere completely different and that moves
> > your code and
> >>triggers a bug.
> > Ya sure, I will test the same test code on uboot with caches disabled.
> >>>> In RTEMS on the other hand you are running with enabled interrupts and
> >>>> task switches. So RAM access are more or less guaranteed during a
> longer
> >>>> flash operation if you don't lock the interrupts.
> >>> Okay, got it.
> >>>> > You had mentioned there are a lot of possible reasons for a
> >>>> > RTEMS_FATAL_SOURCE_EXCEPTION, is it somewhere documented what all
> > reasons
> >>>> > can cause this exception. Any references would be very much helpful.
> >>>> Basically for an ARM system, you have that source:
> >>>> cpukit/score/cpu/arm/arm-exception-default.c:24:  rtems_fatal(
> >>>> RTEMS_FATAL_SOURCE_EXCEPTION, (rtems_fatal_code) frame );
> >>>> That is default handler for all exceptions where no extra handler is
> >>>> installed. So basically every exception that is listed in the ARM
> manual
> >>>> can be the source.
> >>> Thank you that was helpful.
> >>If you have a debugger connected, you can set a breakpoint to that
> handler
> > and
> >>maybe to _Terminate. Sometimes you can get a source together with the
> > reference
> >>manual of your processor.
> > Sure, we will look in to it.
> >>Maybe take a look at your linker command file or use objdump to analyze
> > your elf file. Something seems odd
> >>there.
> > Below is content of linkcmd
> > MEMORY {
> >    RAM      : ORIGIN = 0x40008000,  LENGTH = 64M - 512k - 32k
> >    RAM_MMU  : ORIGIN = 0x40008000 + 64M - 512k - 32k, LENGTH = 32k
> > REGION_ALIAS ("REGION_START", RAM);
> > REGION_ALIAS ("REGION_VECTOR", RAM);
> > REGION_ALIAS ("REGION_TEXT", RAM);
> > REGION_ALIAS ("REGION_TEXT_LOAD", RAM);
> > REGION_ALIAS ("REGION_RODATA", RAM);
> > REGION_ALIAS ("REGION_RODATA_LOAD", RAM);
> > REGION_ALIAS ("REGION_DATA", RAM);
> > REGION_ALIAS ("REGION_DATA_LOAD", RAM);
> > REGION_ALIAS ("REGION_FAST_TEXT", RAM);
> > REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
> > REGION_ALIAS ("REGION_FAST_DATA", RAM);
> > REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
> > REGION_ALIAS ("REGION_BSS", RAM);
> > REGION_ALIAS ("REGION_WORK", RAM);
> > REGION_ALIAS ("REGION_STACK", RAM);
> > REGION_ALIAS ("REGION_NOCACHE", RAM);
> > REGION_ALIAS ("REGION_NOCACHE_LOAD", RAM);
> > bsp_stack_irq_size = DEFINED (bsp_stack_irq_size) ? bsp_stack_irq_size :
> > 4096;
> > bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size :
> > 1024;
> > bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ?
> > bsp_section_rwbarrier_align : 1M;
> Looks OK to me. It's still odd why the PC was on some flash address. I
> don't think that I can help you a lot more at the current point. So I'll
> just let you investigate on that topic some more.
> > *Amarnath MB*
> > On Fri, May 3, 2019 at 1:37 PM Christian Mauderer <
> >> Hello Amarnath,
> >> programs show them as a solid line) at the front of the lines intact and
> >> don't use ones on your newly written lines? Otherwise it's a little
> hard to
> >> see the answers. There's normally no strong formatting requirements on
> this
> >> to keep the mails readable.
> >> > On Thu, May 2, 2019 at 3:35 PM Christian Mauderer <
> >> >> > Gesendet: Donnerstag, 2. Mai 2019 11:18:48
> >> >> > Hi Christian,
> >> >> > As per your suggestion, i tried disabling  global interrupt before
> my
> >> >> erase
> >> >> > call and enabling it afterwards. With this setup the test routine
> is
> >> >> > passing without giving exception. So i think, interrupt was the
> issue
> >> >> here.
> >> >> Hello Amarnath,
> >> >> good. Than you have at least a hint toward the problem. I wouldn't
> see
> >> it
> >> >> as the solution. Like already discussed, depending on your
> application,
> >> >> this can lead to missed interrupts. If you have a very specific case
> for
> >> >> writing the flash that isn't during your normal operation (for
> example
> >> >> firmware updates) you are most likely fine with that solution. But if
> >> you
> >> >> write for example log files, you might get a quite unpredictable
> >> behavior
> >> >> later.
> >> >> Hi Christian,
> >> > Thank you for the detailed explanation. Even though we are using NOR
> >> > flash for firmware storage, there is a chance that it may be used for
> log
> >> > files later.
> >> interface
> >> >> in
> >> RAM
> >> >> and
> the
> >> >> RAM,
> >> case). I
> look
> >> at
> >> > documentation.
> would
> >> be an odd design), you might can move the RAM and Flash to an
> independent
> >> bus or maybe add some kind of bus bridge to separate the Flash. But I'm
> not
> for
> >> a
> a
> >> flag
> you
> >> external
> have
> >> a
> >> >> problem
> >> disable
> >> >> all caches.
> NOR
> behavior
> >> changes? It could be a bug in disguise if the U-Boot code only works
> due to
> >> caches. These are quite nasty because they sometimes depend on the exact
> >> position of the code. In most cases it works because the loop is in the
> >> cache but if for some reason the processor has to load a new cache line
> for
> >> the loop it doesn't work. Really hard to find because you can change
> >> something somewhere completely different and that moves your code and
> >> triggers a bug.
> and
> longer
> >> > Okay, got it.
> >> reasons
> helpful.
> manual
> >> >> can be the source.
> handler
> >> and maybe to _Terminate. Sometimes you can get a source together with
> the
> >> reference manual of your processor.
> >> >> > Thank you once again for your prompt response, it really saved lot
> of
> >> our
> >> >> > time.
> >> >> > Below is the exception frame we got,
> >> >> > FYI, 0x0 - 0x007FFFFF is NOR Flash and 0x40000000 to 0x7FFFFFFF the
> >> RAM.
> >> >> Yust a note: Putting memory at 0 might hides some NULL-pointer
> accesses.
> >> >> If you can do that in your design you might want to think about
> putting
> >> >> some boot ROM there that isn't accessible by the application (for
> >> example
> >> >> locked via MPU).
> >> > I got it. We have kept uboot at 0x0 and RTEMS at 0x40000 offset of
> flash,
> >> > we have restricted access from application to these uboot and RTEMS
> >> > sectors.
> >> >> Of course there can be worse types of memory Flash (which should be
> >> mostly
> >> >> a read only memory). I had a controller with some RAM there once.
> >> Finding
> >> >> NULL-pointer accesses on such a system is really nasty.
> >> >> > *** FATAL ***
> >> >> > fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION)
> >> >> > R0   = 0x00000040 R8  = 0x00100000
> >> >> > R1   = 0x00080000 R9  = 0x00000001
> >> >> > R2   = 0x00000048 R10 = 0x4010a3e8
> >> >> > R3   = 0x00000048 R11 = 0x4011737c
> >> >> > R4   = 0x00000a00 R12 = 0x00000000
> >> >> > R5   = 0x00000500 SP  = 0x40100c40
> >> >> > R6   = 0x00000055 LR  = 0x4000a36c
> >> >> > R7   = 0x000000aa PC  = 0x003fde80
> >> >> > CPSR = 0x200000d2 VEC = 0x00000001
> >> >> > RTEMS version: 5.0.0.
> >> >> > RTEMS tools: 7.4.0 20181206 (RTEMS 5, RSB
> >> >> > 40ae056f12e1cbe530f76a3ebd1e2ac745a888ef, Newlib
> >> >> > dc6e94551f09d3a983afd571478d63a09d6f66fa)
> >> >> > executing thread ID: 0x08a010002
> >> >> > executing thread name: Alpi
> >> >> Your program counter (PC) points to a Flash address here. Are you
> sure
> >> >> that your application runs entirely from RAM?
> >> > We are sure that RTEMS is executing entirely from RAM, we are
> debugging
> >> on
> >> > this issue.
> >> your elf file. Something seems odd there.
> >> Best regards
> >> Christian
> >> >> Best regards
> >> >> Christian
> >> >> > *Amarnath MB*
> >> >> > On Thu, May 2, 2019 at 12:49 AM Christian Mauderer <
> >> >> >> > Gesendet: Mittwoch, 1. Mai 2019 17:07:13
> >> >> >> > Hi Christian,
> >> >> >> > Thanks for your quick response.
> >> >> >> > Our boot process is like, first u-boot will be loaded from the
> NOR
> >> >> flash
> >> >> >> > and then the uboot copies RTEMS application from NOR flash to
> the
> >> RAM.
> >> >> >> > After that RTEMS executes entirely from RAM.
> >> >> >> > How can i issue a global interrupt disable? Is it using *
> >> >> >> > rtems_interrupt_disable(0)*?
> >> >> >> > One more doubt, if i issue a global interrupt disable then will
> >> there
> >> >> be
> >> >> >> > chance that i can miss few clock ticks?
> >> >> >> > *Amarnath MB*
> >> >> >> Hello Amarnath,
> >> >> >> with a global interrupt lock, all kinds of events can be missed
> >> >> including
> >> >> >> clock ticks. Most should be processed just a little late but some
> >> >> >> interfaces might loose packets or data (depending on the data
> rate /
> >> >> flash
> >> >> >> access times). So if not necessary it's not a good solution.
> >> >> >> The rtems_interrupt_disable() function should be called with a
> level
> >> >> >> argument. See the example at
> https://docs.rtems.org/branches/master/c-user/interrupt_manager.html#rtems-interrupt-disable
> >> >> >> Note that for SMP configurations, you might have to use other
> >> functions.
> >> >> >> But if your application runs entirely from RAM than the bus access
> >> >> >> shouldn't be the problem. So the interrupt might isn't the right
> >> guess.
> >> >> >> Do you have any more information on the exception and where it
> >> happens?
> >> >> >> Some output or a stack trace from a debugger?
> >> >> >> What kind of flash controller is used? Can it block bus accesses
> for
> >> the
> >> >> >> RAM? Does your RAM share pins with the flash?
> >> >> >> With kind regards
> >> >> >> Christian
> >> >> >> > On Wed, May 1, 2019 at 8:16 PM Christian Mauderer <
> >> >> >> >> > An: "RTEMS Users" <users at rtems.org>
> >> >> >> >> > CC: "Ravi G Patil" <ravigp at mistralsolutions.com>, "Shekhar
> >> Suman
> >> >> >> Singh"
> >> >> >> >> > Gesendet: Mittwoch, 1. Mai 2019 16:28:23
> >> >> >> >> > Betreff: RTEMS_FATAL_SOURCE_EXCEPTION in RTEMS
> >> >> >> >> > Hi All,
> >> >> >> >> > I'm developing RTEMS 5.00 BSP and device drivers for a custom
> >> >> >> ARM926EJ-S
> >> >> >> >> > core. I was successful in porting and building BSP for the
> ARM
> >> >> core.
> >> >> >> >> > We are facing a strange issue with the generic NOR flash
> driver
> >> we
> >> >> >> have
> >> >> >> >> > developed. Our device drivers are designed such that it can
> be
> >> used
> >> >> >> with
> >> >> >> >> > RTEMS as well as the bare metal programs.
> >> >> >> >> > Our driver is working fine in bare metal program (erase,
> read,
> >> >> write
> >> >> >> >> > everything), but when we use the driver with RTEMS
> application
> >> and
> >> >> >> issue
> >> >> >> >> an
> >> >> >> >> > erase call, then the application gives
> >> >> RTEMS_FATAL_SOURCE_EXCEPTION.
> >> >> >> >> > For testing driver in RTEMS, we have added each test routine
> as
> >> a
> >> >> >> custom
> >> >> >> >> > shell command using rtems_shell_add_cmd().
> >> >> >> >> > For your info we also tested the same driver with u-boot and
> it
> >> >> works
> >> >> >> >> > fines.
> >> >> >> >> > Can anyone guide me on this issue?
> >> >> >> >> > *Amarnath MB*
> >> >> >> >> Hello Amarnath,
> >> >> >> >> it's a little hard with the given information to tell you a
> >> concrete
> >> >> >> >> problem. There are a lot of possible reasons for a
> >> >> >> >> From your description, my guess would be some problem with an
> >> >> interrupt.
> >> >> >> >> Most U-Boot code avoids interrupts. I don't know about your
> bare
> >> >> metal
> >> >> >> >> application but maybe in some test application, you don't have
> too
> >> >> much
> >> >> >> >> interrupts too. In RTEMS you have most likely at least a
> periodic
> >> >> tick
> >> >> >> >> interrupt.
> >> >> >> >> Do you execute your code from the same flash or do you keep
> some
> >> >> data in
> >> >> >> >> the flash? In that case it could be an access error during a
> flash
> >> >> >> erase or
> >> >> >> >> write (for example caused by an interrupt). In that case you
> might
> >> >> have
> >> >> >> to
> >> >> >> >> do a global interrupt disable before you enter certain
> routines.
> >> >> >> >> Best regards
> >> >> >> >> Christian
> >> embedded brains GmbH
> >> Christian Mauderer
> >> Dornierstr. 4
> >> D-82178 Puchheim
> >> Germany
> >> email: christian.mauderer at embedded-brains.de
> >> Phone: +49-89-18 94 741 - 18
> >> Fax:   +49-89-18 94 741 - 08
> >> PGP: Public key available on request.
> >> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
URL: <http://lists.rtems.org/pipermail/users/attachments/20190503/e6205729/attachment-0002.html>
