SMP working?
Sun May 5 19:37:25 UTC 2019
The erc32 is a single core processor and smo is not going to work at all.
You need to be using the Leon3 in the sparc family.
On Sun, May 5, 2019, 12:31 PM Eghonghon Eigbe <eghonghoneigbe at gmail.com>
wrote:
> ---------- Forwarded message ---------
> From: Eghonghon Eigbe <eghonghoneigbe at gmail.com>
> Date: Sun, 5 May 2019, 6:00 pm
> Subject: SMP working?
> To: <users-request at rtems.org>
> Hello RTEMS community,
> I am working on a multiprocessor based project  and I am planning on using
> RTEMS for that. I have been trying to run the example testsuites (smp01,
> smp02, etc.) on the standard erc32 however when I run it with gdb I do not
> see any output on the terminal. All I have done is enable smp (using
> --enable-smp) and run the testsuites as stated in the Quick Start.
> I do not understand why I do not get an appropriate output (as the source
> codes for smp include print statements I am sure I should see something).
> It is stated that the SMP support is a work in progress which is why I
> wanted to ask the mailing list if there is something that I am missing or
> if rtems is not fully ready for smp support.
> Best Regards,
> Suhail, Eghonghon
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20190505/56bfe82d/attachment-0002.html>
