Shell bug(?)
Gedare Bloom
gedare at rtems.org
Sat Nov 2 16:32:10 UTC 2019
The question is whether your driver is actually pending indefinitely as you
think, or just the shell is running during the small sleeps.
On Sat, Nov 2, 2019, 9:06 AM Joel Sherrill <joel at rtems.org> wrote:
> On Sat, Nov 2, 2019, 12:03 AM <mbenson at windhoverlabs.com> wrote:
>> That’s kind of my point. The low priority shell task is working
>> perfectly. The higher priority task is pended by time. I do have some
>> sleep functions in the driver code but they are short sleeps. They
>> shouldn’t just pens indefinitely until a run any random command in the
>> shell. Unless I’m not understanding the priority model correctly and have
>> inadvertently inverted my prioritities.
> The shell has to be the executing task to run the command and produce
> output. It is only running when nothing else is running in your system. But
> the reports will never catch another task ready because if it was ready,
> the scheduler would pick it to be the executing thread.
> It looks and sounds odd but it is exactly what is supposed to happen. It's
> lowest priority and produces output when it runs.
>> Sent from my iPhone
>> On Nov 1, 2019, at 14:40, Joel Sherrill <joel at rtems.org> wrote:
>> On Fri, Nov 1, 2019 at 12:33 PM Gedare Bloom <gedare at rtems.org> wrote:
>>> On Fri, Nov 1, 2019 at 10:52 AM Mathew Benson <mbenson at windhoverlabs.com>
>>> wrote:
>>>> So no matter what priority the shell task is initialized as, it
>>>> preempts all other tasks?
>>>> No.
>> But an odd artifact of looking at the status of threads in the shell is
>> that the shell thread has to be **EXECUTING** to do that. Since this is a
>> single core system, it means all other threads are either blocked or ready
>> and have a lower priority.
>>> With low priority (250) under the default scheduling (fixed priority
>>> round-robin), the shell would only run when higher priority tasks are
>>> blocked. This is typical, and the shell will be preempted when higher
>>> priority tasks are made ready. The "TIME" state indicates your driver task
>>> self-suspended on a timer, e.g., nanosleep or wake_after type call. It
>>> should preempt the shell after the timeout. If it isn't then something is
>>> going strangely.
>> Yep.
>>> As Joel hinted, if you're using POSIX threads, then 250 is higher
>>> priority than 235.
>> But I don't know how this is reported by the command he is using. I
>> recall one command to list Classic API tasks and one for POSIX threads. I
>> don't recall one which lists all but I could be wrong.
>> --joel
>>> Gedare
>>>> On Fri, Nov 1, 2019 at 11:36 AM Joel Sherrill <joel at rtems.org> wrote:
>>>>> On Fri, Nov 1, 2019, 11:24 AM Mathew Benson <mbenson at windhoverlabs.com>
>>>>> wrote:
>>>>>> My shell task is set to priority 250. I have another task that I've
>>>>>> set to a priority of 235. When I have the shell in the build, that
>>>>>> priority 235 task appears to pend indefinitely with the shell reporting
>>>>>> state = "TIME" and I don't know where it would be pending. The task is
>>>>>> accessing NOR drivers. But just by running the shell command, releases
>>>>>> that priority 235 task. In fact, any command releases it. Whether its a
>>>>>> valid command or not. But if I remove the shell from the build, everything
>>>>>> is fine. The task doesn't pend. It executes as it should. Did I miss
>>>>>> something in the documentation regarding integration of the shell? Is
>>>>>> there something we are or are not supposed to do when the shell is
>>>>>> integrated?
>>>>> I'm off today and this is from my phone.
>>>>> TIME should indicate that the task is sleeping. Assuming these are not
>>>>> POSIX thread priority The priority 235 task has to be blocked or the shell
>>>>> task won't run at all. So anytime your shell task runs, the others should
>>>>> be blocked.
>>>>> --joel
>>>>>> *Mathew Benson*
>>>>>> CEO | Chief Engineer
>>>>>> Windhover Labs, LLC
>>>>>> 832-640-4018
>>>>>> www.windhoverlabs.com
>>>>>> _______________________________________________
>>>>>> users mailing list
>>>>>> users at rtems.org
>>>>>> http://lists.rtems.org/mailman/listinfo/users
>>>> *Mathew Benson*
>>>> Windhover Labs, LLC
>>>> 832-640-4018
>>>> users mailing list
>>>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20191102/2759403f/attachment-0001.html>
