Adding cpp driver to RTEMS build
Vishav.Vishav at dlr.de
Mon Nov 18 15:22:23 UTC 2019
Hello,
Sorry for the confusion. I want to include the device driver as part of bsp and not an application. I am creating a custom bsp. I have already successfully added gpio driver to my custom bsp. All the files for gpio were written in C. But for this new device driver is written in cpp. When I try to add it, the compiler fails to compile it. In fact, no compiler is called to compile this cpp file.
Kind Regards,
Vishav
-----Original Message-----
From: Sebastian Huber [mailto:sebastian.huber at embedded-brains.de]
Sent: Montag, 18. November 2019 15:31
To: Vishav, Vishav; users at rtems.org
Subject: Re: Adding cpp driver to RTEMS build
Hello Vishav,
C++ is well supported in general. Which RTEMS version do you use and how
did you get to your RTEMS tools (e.g. compiler, linker, etc.)? Which
architecture and BSP do you use?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
